wow. you have an FX-60 that is missing the multipliers.
thanks man. anybody willing to donate me an extra multiplier to use on this chip? :lol: :D
Originally Posted by fareastgq
I will do it in a heartbeat if I have better cooling to keep the massive heatload in check, this thing really tax the crap out of this single stager! :D
have you reached the point to where you wont be using your single core much longer?
It's quite the opposite, I'm starting to missed the flexibility of my 148 as the 11x multiplier is VERY handy, unless I buy more ram that could clock higher, or find a 175 that could clock as well as this chip otherwise it's possible that I 'might' go back to single core....I still can't decide at the moment :lol: One thing for certain though, I wouldn't hesitate to run this 170 at 3.20Ghz @1.56v for 24/7.Quote:
Originally Posted by AndrewZorn
3.2ghz with voltage like that is perfect for daily use...
i was talking to someone today and i told him something, that i cannot believe how spoiled i have become... i got an hourglass yesterday when doing daily type stuff. so simple, so 'expected' by most, but it really bothered me. i am so used to never having to wait for ANYTHING, and i love it.
besides Q4 and the like being dual-core capable, id stick with the dualie...
anyway, we both know anything above 10x is for suckas.
I think you can really make your CPU and mem fly with an Expert. You should try it before ditching your CPU.
Ben, if you do go back to single core, can i buy that 170 off of you?
WOW. i just realized he had the asus...
which makes it a more amazing feat, but is somewhat disappointing...
get an expert, or at least a slider!
I don't think any SS can handle taht kind of heatload. At least a SS for normal use 24/7 unlike a uber 1hp rotary style:cool: Very ncie chip and keep that sucker clocking.Quote:
Originally Posted by ben805
I'm using the Ultra-D AD0 at the moment and it's only good for 334 HTT so I'll most likely ditch this board for the Expert, for now I'm just playing it safe and wait few more weeks to see how well the Expert hold up.Quote:
Originally Posted by thunderstruck!
I don't think we can discuss that matter here but if I ever give up either one I'll put it on Classified ;)Quote:
Originally Posted by Red.Sky
Agreed, and a big compressor with the right :banana::banana::banana::banana:tail will hold this 170 @3.30Ghz for 24/7 no problem but it's going to be loud as hell :lol: this puny little Masush|ta compressor is pretty much very close to if not already maxed out so I don't think it would go past 3.25Ghz to do dual prime. I'd ordered some 2GB Gskill HZ from newegg earlier and should received them next Wednesday, once I get them in I'll push it as far as I could and post back some more results :D :DQuote:
Originally Posted by Cpt Twitchy
Just a word of warning - you may not have such a great experience with certain 2gb kits and the expert - you're probably better off sticking with the Ultra-D in terms of compatibility with different types of memory.Quote:
P.S. - If you really wanna see what that cpu is capable of @ AT LEAST DI temps, feel free to send it to me and I'll toss it on my autocascade :D
What kind of 2GB kits might have issues on the expert? UCCC? if it's not appropriate to post it in the public please let me know via PM :p:Quote:
Originally Posted by s7e9h3n
I'll see if I can get hold of a mousepot and some DI around here, if not then I might take up your offer and let you play with it for a week and see what it can do under your autocascade :lol: :D by the way, what's your autocascade holding temperature and can you guess how far can you push this 170?Quote:
I got some of this on Monday, seems happy at 250 3-3-3-8 at the moment in the Expert with a x2 3800 Toledo, which is better than spec.Quote:
My autocascade is a freakish phase unit - evap temps on my FX57 @ 1.68ish are around -73C and loaded @ -67C :cool: . It all depends on how well the memory controller will take the cold. The best CCBWE I've seen to date is an x2 4800 which is able to run @ ~-55C Core temps. I'd say on average though, the CCBWE's seem to crap out @ around -35C - -40C core. Your cpu @ approx 1.6 - 1.65V will probably be a perfect fit with the auto. Here's a little bios shot from my FX57 a couple days ago:Quote:
http://img392.imageshack.us/img392/6553/455pb.jpg
as soon as my winni is selled i will get oneQuote:
429 in ger now. :)
s7e9h3n: have u got a golden tip for me, on how to handle my ccbwe mem ctrl?
280-285mhz seems to be the absolut max i can get my z503s to run stable with the cpu in #0 and drive / data strenght 5 / 1 appears best.
295mhz wasn't a problem with my previous 3700+ even with only 2,6v.
where are you guys getting 0550 UPMW 170s? I could only find the 165s from TankGuys (I ordered 2 they will be here on Monday). But I could not find anyone selling 170 0550UPMWs... :confused:
i got mine of ebay, and i may have access to more 170 0550's, so if youre interested in buying one, polssibly PM me? i duno the seller needs to get back to me
If only it were that easy to figure out these things :p: TBH, I don't have much experience with the 2gb kits, but there could be numerous things that are preventing your OC from reaching the levels of your 3700+. As you probably know, you simply just can't expect as high of an OC with a dual core as a single core. What Vdimm are you running @ 280 with your dual core? IMO, running drive/data of 5/1 is a little weak unless you're running in extreme cold. On average, I never run below 7/2 on any of my memory. Have you tried 7/auto? Problems such as these don't really have any quick answers - you basically have to try to narrow the problem down through trial and error. It may just be that your dualcore simply isn't able to run as fast as your single ;) .........Quote:
Originally Posted by mag|c
:woot:Quote:
My CCBWE and LS are getting married. :D
Yup, for the most part, people seem to be able to avoid the cold-bug on x2's by running VapoLS's :DQuote:
Originally Posted by stone_cold_Jimi
It could be a case of your ballistix ironically degrading at the time in which you switched cpu's. As you already know the recent batches can last from 2 days up to 6 months from my experience.Quote:
Maglc, Stephen and Shure are right...try 8/3, 8/2 for drive and data strength, or leave them on auto, 5/1 is too weak. And it's very possible that your Z503 is on it's way out as well, usually these suckers won't last too long, I went through 3 pairs and all of them died within 2~3 weeks.
could the drive and data strength be holding back an oc? i have no clue what that is and what it does, but when i get my chip i want nothing to hold back the oc except for tempsQuote:
woohoo can't wait to see results:toast:Quote:
Originally Posted by tHe_jOkeR
