@leejsmith,
I would not be caught dead benching or running everest with all that stuff running in the background. Your windows taskmanager reports 31 processes running.
@leejsmith,
chill it's just my 24/7 everyday setup if i was benching i would have a tweaked os with minimal services running and no antivirus ect.
Originally Posted by IluvIntel
hi all
im not sure whether to take a cedarmill 631 cpu or a presler 920. but here in germany are only presler available, cedarmill not in stock :(
and by the way(because i see something about a 630 record)
look at my superpi bench with 630 watercooled, temp ~70°C load (HS is crappy)
630 super pi bench
I had the same dilemma with u but i've decided to go Presler.Quote:
Originally Posted by son_of_liberty
The way i see it is that from a 6x0 to a 6x1 cpu u won't notice any performance differences except (maybe) from higher oc.
So i'm going to change my 640 with a 920. :)
What about less Vcore ? as well as Higher O/CQuote:
Originally Posted by JoeBar
I agree with u, but it's like your 630 could do 4.6ghz... ;)Quote:
Where Did You Guys get cedarmil cpus ?? When it will be available in sale ?
Originally Posted by wampir
Alot of online stores have them http://www.tigerdirect.com has OEMS and a couple other stores came up on google for retails (Tiger has bundles with pretested mobos)
my Cedarmill arrives in two days,can't wait to see hughe mhz on air
and i'm testing a Scythe Ninja under -2 degrees
http://img145.imageshack.us/img145/2...wd2eair0la.jpg
http://img508.imageshack.us/img508/2...agem1506uo.jpg
winter rox :up:
I just ordered another Presler, LOL. You should be able to get 5GHz pretty easily with air like that. Good luck with it!
Here a good 920, did 4,5ghz @spi1m@1,5v( 1,42-1,45 under load :stick: ), with about 20c ambient temp and a big typhoon, will post pics when i get some free time... :)
When you post the pics say/show the temps because i'm thinking on getting a 920D too but i wanted to know what is his behaviour under a TT Big Typhoon.Quote:
Originally Posted by ^don.k's^
@ boostedevo
i'm waiting for a cheap 631(keeping money for Yonah and Aopen), with my room temp and good cooling 5ghz will be easy.
what Presler u got?
@ dutchman.pt
SCYTHE NINJA vs THERMALTAKE BIG TYPHOOM
http://i28.photobucket.com/albums/c2...hz130vidle.jpg
http://i28.photobucket.com/albums/c2...estock3ghz.jpghttp://i28.photobucket.com/albums/c2...estock3ghz.jpg
http://i28.photobucket.com/albums/c2...lefullload.jpg
http://i28.photobucket.com/albums/c2...3ghzpi32mb.jpghttp://i28.photobucket.com/albums/c2...3ghzpi32mb.jpg
http://i28.photobucket.com/albums/c2...stock36ghz.jpghttp://i28.photobucket.com/albums/c2...stock36ghz.jpg
http://i28.photobucket.com/albums/c2...0vfullload.jpg
http://i28.photobucket.com/albums/c2...6ghzpi32mb.jpghttp://i28.photobucket.com/albums/c2...6ghzpi32mb.jpg
http://i28.photobucket.com/albums/c2...hz147vidle.jpg
http://i28.photobucket.com/albums/c2...ore1474ghz.jpghttp://i28.photobucket.com/albums/c2...ore1474ghz.jpg
http://i28.photobucket.com/albums/c2...7vfullload.jpg
http://i28.photobucket.com/albums/c2...4ghzpi32mb.jpghttp://i28.photobucket.com/albums/c2...4ghzpi32mb.jpg
http://i28.photobucket.com/albums/c2...hz151vidle.jpg
http://i28.photobucket.com/albums/c2...ore1514ghz.jpghttp://i28.photobucket.com/albums/c2...ore1514ghz.jpg
http://i28.photobucket.com/albums/c2...1vfullload.jpg
room temp 15C
sry for the long post
I'll have a 661 for sale probably, but not as cheap as a 631 :) Yonah+AOpen = REAL good stuff...still loving that 23s 1M SPi I saw on one @ 2.7GHz.Quote:
what Presler u got?
I was going to wait until EIST/LockFree was possibly reinstalled in them, but I ordered a 930 after a guy on another forum just received his and had it going @ 5GHz on cold air...just pushed me to do it. They're still all the same cores/revisions so it's just luck of the draw with binning I guess...I hope it's better than the first one I tried...
Anyone here using a 940 or 950 ?
I would like to know if they have "cpu lock free" feature available on either Asus or Gigabyte 975X mobos, before I commit to 661...:confused:
Lucky u! :)Quote:
Mine struggles for 4.2ghz.
@ boostedevo
i got a strong 930 for overclock just need a better cooling to push like you and good luck with your new chip
my new aircooled chip
Cedarmill 631 + Scythe Ninja
http://i28.photobucket.com/albums/c2...zpi1mbboot.jpg
http://i28.photobucket.com/albums/c2...317mhzcpuz.jpg
http://valid.x86-secret.com/show_oc?id=70692
ambient temp PcCI2iminal ?
PC, very nice chip! You need better mem for those SPi's though :)
No 65nm Intel has LockFree or even EIST right now, including the 661.Quote:
@ Byron
room temp 5C
@ boostedevo
im looking for new rams my friend , 15x348 @ 4-4-4-4 @ 1/1 hurts my system,or more clock or better ram ,any help with DDR2?Corsair UL or what?
the max stable clock for Corsair XMS2 Pro @ 4-4-4-4 is 420mhz
http://img269.imageshack.us/img269/1...hzpi1mb7gq.jpg
IluvIntel i have 940 , and u cant chang the multipler, there is no iest .
Thanks boostedevo, thats really annoying how they do that (Intel) and you say even the mobo vendors like Asus can't enable it with "cpu lock free" feature.Quote:
Originally Posted by boostedevo
mmmmm, I'll have to think about this. :fact:
Yeah, it's cut out of the current chips from Intel, it's nothing as simple as what a BIOS update can fix. Q2 for EIST on any of these 65nm's and I have NOT heard whether that will even include LockFree at that time....we'll just have to wait and see.
This new 930 I got today is a 10000x better than the first one I got. I need to fix my droop, but I should be able to bench this thing at the same clocks as the 661(!) IF the single stage will handle it. I've got PLENTY of Vc left for 5.3GHz+, but I have to get rid of the droop on load or I'll need to set it artificially high to make up for it (which I don't want to do).
It's an OEM, so no pack date. Malay proc and I got it from TigerDirect.
http://i10.photobucket.com/albums/a1...930-2/5181.gif
I am doing some EASY 4950MHz 3D benches tonight (set for 1.525Vc, 1.45-1.46V actual on load) and it's just crushing my 661 scores....stable as hell. My first 930 wouldn't bench 4.5GHz @ 1.50V and wouldn't go over 4.65GHz AT ALL without crashing inside of 30 seconds....this new one is just amazing by comparison...
That is absolutely bloody amazing mate ! You are most certainly one lucky user !! :DQuote:
I wish I had that chip, its the luck of the draw though....:fact:
Yeah, it's definitely luck. I was going to hold out and wait for EIST/LockFree before getting another Presler too, but another guy ordered a retail 930 from Tiger and was doing 5GHz on air (Scythe, REAL cold amb tho), so that "forced" me to risk it ;) Either lightning struck twice or they are getting towards their stock with better binnings :)
