Originally Posted by g0dM@n
Wow, I overlooked all of those. Good points. Well, I guess my point kinda does make sense when you think about the whole SLI thing. If you're not going SLI at all, then it's kinda worth it... only thing is that the ram voltage options are awesome on the Expert. :D
Dude, I SERIOUSLY think that it's your divider that is causing you your problems. Before my opty170, my opty148 was my main rig and I had a 144 as my 2ndary. They 148 would run my 180 divider with my bh5 ram without a problem. I was running 275-280fsb x 11, but my ram was only at high 230s that way (~240mhz @ 1.5-2-6-2). That was NO WHERE near what my ram could do, so I went ahead and used someone's divider/fsb program (I forget who made it, but there is a prog that I was using that helps you out where you plug in the cpu freq you want and ram freq and it gives you lists).
I also read up about how the dividers are calculated exactly and figured out that at 300htt and 166 divider that the ram does 250mhz, which was almost perfect in my case.
So... I went ahead and tried the x10 multi. The board would NOT even get to windows logo without rebooting at anything above ~285HTT with the 166 divider. I took a guess and decided it was the divider that was screwing it up. Unfortunately, I had sold all of my TCCD before purchasing the 148 (I had the 144 for a little bit before the 148 and had no issues with UTT or BH5).
I figured that I'd try to use no dividers with the x10 multi to prove a point. I went ahead and bought some OCZ Plat Rev2 3200 off ebay. I threw those suckers in at 300x10 with a 1:1 multi at 3-4-4-8 and wabaam!!! I made it to windows without a hitch!
I ended up stabilizing 300x10 2.5-4-3-7, and probably coulda pushed more, but I definitely proved to myself that the 166 divider in combination with the x10 multi wasn't working.
Conclusion: always test your dividers and play with them, especially when it comes to figuring out the max HTT of your mobo. Another good thing to test is even LOWER multis (maybe x7 or x8) cuz they may work differently (better) with dividers.
You cannot claim that a board doesn't do a certain HTT without trying out all of these factors... don't forget, LDT voltage and chipset voltage may help as well.
I know you said that you tried different voltages, but maybe if you can't borrow a TCCD/5 set from someone, then you can try lower CPU multis with the dividers and see if that helps. Not for all, but dividers are REALLY picky with some setups...
