ill give it a try thru windows lol ...
cant do all the switches thou ?
I am always using Winflash for flashing the bios. I used it with my old sli-dr board and for my curren Rdx200 board also. Bt the way I would like to pick one of these mobos soon to give it a try
Flashed with new bios currently with my 144 opteron at 3106mhz with a HTT of 345
hi Tony !Quote:
Originally Posted by Tony
nice Bios :thumbsup:
Merlin ;)
When it comes to tight timings, this board is pretty hard to beat. Trfc = 11. Read preamble = 4ns. Using Mushkin Level 2's (2X512).
http://img491.imageshack.us/img491/4...0x1432m6zs.jpg
Tony, did you have any luck with Expert and cold bug CPUs? I spent the day dice benching with Expert trying to get past cold bug and had no luck.
Boot with all the ram tweaks etc in place but set a low clock etc and get into XP before it gets to cold, then clock with a64 tweaker and clockgen.Its a lot easier with phase but you may struggle with dry ice but its worth a shot.Quote:
Originally Posted by Eldonko
See if that helps
Any update on the vtt stability? :scope:
Tony, do you have any feedback on that CF-BT board? Will it come out or has been placed aside?
Originally Posted by sierra_bound
nice and tight there/..............you reckon you could run it with
TRTW=1
Read Write Queue Bypass = 16
Drive Strength = Normal
MAL=6
would be interesting if it worked...... :cool:
Hmmm, no mention of how GREAT a FSB overclocker the Expert is :p:
PS: This puppy booted right to Windows at this speed:D
http://www.xtremeresources.com/image...0Val%20510.JPG
nice one
never even bothered to check that.....hehe
Very nice! I need to hook mine up. Its been sitting in the box since I got it..LOL
FARRRRRK, I looked at the CPU speed and thought to myself.....HMMM pretty average, then I saw the HTT and fell off my chair :fact: :clap: :slobber:Quote:
Originally Posted by MrIcee
Originally Posted by MonkSP
Hello???? :stick:
Totally awesome bro. When I looked at cpu speed i thought it was mediocre but that HTT WOW! :toast:Quote:
What ram is that and what was max stable HTT does it go into windows with on other mobos?
Hiya Bro:)
On my original SLI-D it would boot to Windows at 425Mhz HTT and no higher. From there I had to use ClockGen to reach 500Mhz, and it was 100% stable. You can see those exploits from March here. This one will boot straight to Windows at 510Mhz HTT. The top stable speed is 505Mhz HTT where I've run 32M SuperPi's and Aquamark, 3D 03 and 3d05.
As far as the type of ram I used for my HTT testing, its listed in the CPU-Z Verification above:) To be Honest, running on the 100 divider it doesn't matter what you run, you're not testing memory bandwidth, just HTT capability:)
Randi:D
Any Inf ce-6 or be-5 2gb set(2x 1gb) accidentally will lost dual channel capability and never fixed? I have tried almost 10 sets. looks like it's just Infaneon IC problem with Expert.
Cold bug kicks in at -55 to -60 for my CPU. Boots fine at low speeds (2800Mhz) but cant touch clockgen without insta freeze. Running prime in the background allows me to bench and tweek all I want but benching while running prime is a waste of time lol. Was hoping Expert would help but I tried all 15 dr str settings, bunch of MALs, etc, no luck beating it. New CPU time I guess ;)Quote:
Hi guys , i am sorry to ask you something that was already post , but wich one is the best BIOS for eXpert & X2 4800? I try to download from one link 11/22 but i couldn't i have no idea why , its says that the server is down.
http://www.abxzone.com/forums/showthread.php?t=88699Quote:
Originally Posted by BobyTT
Thanks a lot!!!!!!!! Respect.
Hey Tony/BigToe/Anyone :)
Has anyone noticed the peculiar behaviour of actual ram MHz when using the 180 divider ??, look at the star marked entries below that were displayed while I was doing some preliminary testing on my 146 using the E704-2BT bios with my new Expert
OPTERON 146 CABYE 0543FPMW xxxxxxxxxxxx00051
CPU MHz-DIVIDER-vDIMM-MB/s-RAM MHz-CPU.VID-SPECIAL.-BIOS VCORE
2600 180 3.22 2605 236 AUTO AUTO 1.41
2650 180 3.22 2655 240* AUTO AUTO 1.41
2700 180 3.22 2706 245* AUTO AUTO 1.41
2750 180 3.22 2756 250* AUTO AUTO 1.41 ERROR TEST 6
2750 166 3.17 2622 229 AUTO AUTO 1.41
2800 166 3.17 2669 233 AUTO AUTO 1.41
2850 166 3.17 2717 237 AUTO AUTO 1.41
2900 166 3.17 2764 241 AUTO AUTO 1.41
2950 166 3.17 2812 245 AUTO AUTO 1.41 ERROR TEST 6
2950 133 3.17 2402 196 AUTO AUTO 1.41
3000 133 3.17 2443 200 AUTO AUTO 1.41 BOOT HUNG
3000 133 3.17 2443 200 1.400 102.4% 1.43
* Wrong Setting for ram MHz
it's nothing wrong with the bios. it's a64 behavior.
most people assume it's fsb * divider = ram speed.
not true.
The athlon 64 memory clock is ALWAYS mem speed = cpu speed / memory divider.
what happens is when you select a memory speed in the bios...the cpu picks a memory divider that would be the closest for that cpu multiplier (it assumes 200 fsb).
EG.
2000 mhz cpu = 200 x 10.
for 200 mhz memory it picks a mem divider of 2000/10 = 200 mhz
for 183 mhz memory it picks a mem divider of 2000/11 = 181.8 mhz
for 166 mhz memory it picks a mem divider of 2000/12 = 166 mhz
for 133 mhz memory it picks a mem divider of 2000/15 = 133 mhz
but say change that to a 2200 mhz cpu (200 x 11).
for 200 mhz memory it picks a mem divider of 2200/11 = 200 mhz
for 183 mhz memory it picks a mem divider of 2200/12 = 183 mhz
for 166 mhz memory it picks a mem divider of 2200/14 = 157.1 mhz
for 133 mhz memory it picks a mem divider of 2200/17 = 127.4 mhz
the a64 will never pick a divider that will put the mem clock over the "target" speed.
In your case.. the cpu has picked an 11 divider
Now apply the 11 divider to your cpu speeds for the 180 setting..and it will all make sense.
hiQuote:
unfortunately still problemme with stabilitet :( :down:
OCZ 3200 Plat. rev2 v1.0 Tccd 2x512Mb
http://hslab.pl/Merlin/300_300.jpg
http://hslab.pl/Merlin/334_300.jpg
http://hslab.pl/Merlin/368_284.jpg
http://hslab.pl/Merlin/368_284F.jpg
Merlin ;)
