no hijack intended, but can someone with the knowledge and hardware start a thread like this for 7900GT's ?
that should be very helpfullQuote:
Originally Posted by graham_h
I have a 7800gt with 1:1 core clocks, the core is crap for overclocking and I am thinking it is because one of the cores can't take the higher frequencies. I was wondering where I could get my hand on some 27 or 40mhz delta BIOS files for an EVGA 7800GT 256-P2-N515-AX? I checked MVKtech but none of the BIOS files are labeled
Great info! My single 256 7800GTX went from 9968 to 10422 3d'05 using H20's BIOS with the tighter timings and going from 600 to 608MHz! :shock: :up:
http://service.futuremark.com/compare?3dm05=1978152
:) hi ya guys, bit of an "outdated:rolleyes: " card now according to sum but i would like to get a little more out my leadtek 7800gtx EXTREME 256.
my stock clocks are 490/1.25ghz and i can overclock it to 550/1.39 on the stock cooling. this produces 9328 3d marks in 05.
if i raise the core by and extra 1mhz it fails the coolbits test.the temp maxes out at 51degrees C.
i run the cpu at stock speeds during the test(2.4ghz).
my aim is to hit 10000 3dMARKS IN 05( iddeally without using LOD). any advice owuld be much appreciated.:) :) :) :) :)
Agreed, this would be awesome info
i agree
I believe that the process is simple, just replace the 7800's delta of 40 with the 7900's default delta of 20, ie add 20 to any of the suggested clocks shown on the front page (eg 25x27=675 - 20 = 655 final clock)Quote:
In my case however, I have flashed my bios and increased the Delta to 50, so I in fact deduct 50 from any multiple of 27, (eg 611 instead of 621).
If I get the point, this is how it works.
great info, anything for a 7900GT?
please anyone have already tried oc with an 70/80 geo? It's better or worst than with 60 geo?
thanks
