:DQuote:
Originally Posted by JuanFlaiter
525/1380 was somekind of limit for me. Few times I managed to get it at 525/1390. I hate Coolbits! It's not meant for serious overclocking. There has to be somekind of method to force the clockspeeds :)
:DQuote:
ohhh JF tirate el review luego en chilehardware ya te delate en oc.cl :)
que buena felicitaciones por la vga
Edita el mensaje maricon!Quote:
Originally Posted by metro_oc.cl
Incredible ln2 work guys. I truly appreciate how hard it is to maintain loaded temps within a specific range, while benching..Benching one of the new cold bug fx's has got to be chore on ln2 :)Quote:
Originally Posted by Sampsa
SLI is going to be very hard for me to do on my own.
Esos insultos amigos
Those hard words m8's
I really suggest you to get yourself a co-overclocker for LN2 SLI sessions. It's almost impossible to tweak the settings and try to keep the temperatures stable (in our case 3 containers: CPU, GPU1 and GPU2), Our teamwork with Kamu works great! I can only imagine benchmarking with cascade, just install the evap and start benchmarking, no worry about cooling :DQuote:
Originally Posted by k|ngp|n
No habla espanjole.. (I think I saw that in some movie) :DQuote:
Originally Posted by Always
sampsa español i know you dont have the ñ in english but know you know is not with nj lol
for the other members that speak spanish dont do it cuz here everybody speaks english and i think if you want to talk in spanish just PM not post in spanish....
sampsa is true that you can control temps with ln2????
We where just kidding, dont worry.
Soy alergico a los crustaceos xD
Yes it's true.Quote:
Originally Posted by leviathan18
Very nice, Sampsa & Kamu... :thumbsup:
I'm really impressed with LN2 on FX-55 San Diego :toast: Do you think it has anything more in it, to beat OPP's 3635Mhz 3D stable? Or that's about all you guys can do with -60C on the container?
I assume OPP's FX-55 is 130nm Sledgehammer which has no cold bug. I should try to hunt one of those but unfortunately we have very limited supply for FX-55s here in Finland :(Quote:
Originally Posted by bachus_anonym
I think 3,6 GHz could be possible with very careful fine tuning (and I mean 3DMark05 stable, not Spi1m :)
Yes, OPP's FX-55 is a 130nm ClawHammer... I'll keep my fingers crossed for you guys getting that 3.6GHz :) Excellent teamwork on LN2 benching :toast:
Hey Bachus,Quote:
I guess you may have missed this post: :eek:
3.9+ @ -48, 3.7 Benchable
So order one from Sweden, Denmark or Norway? Aint that hard :)Quote:
we are kinda mates :)Quote:
wont speak in spanish any more :toast:
You know geforceti4200 has a point (around post 135) when he says these newer games are very cpu bound. Those results (less fps for SLI !!) make me seriously reconsider buying 2. I still want a next gen card, but now am not so sure whether or not I care to own 2. 3dmarks be damned, these things are expensive! i think it might be a good idea for some people to own an sli board for future proofing, but i ebay my cards when a new one comes out anyway so its not like the ability to add another card in the future is that appealing to me. Anyways, I await more benchmarks to make my decisions, but Farcry and Half-Life 2 are two games I play. Have to see how they do with Alan Wake, Unreal Tournament 2006, and Q4...
You can disable the internal test in rivatuner to force higher clocks. Doesn't it work for the 7800GTX?Quote:
This is a known problem with the 110nm process Samspa, it also happens to 6600 series believe it or not. If I use earlier drivers then it goes down to 28-29C but then still does not report lower.Quote:
Have you tried powerstrip for overclocking ?
Regards
Andy
Rivatuner with "Disable internal test" and "Force performance to 3D" I encountered serious performance drop when going above 525/1380.
With Powerstrip I faced even worse performance drop at even less clock speeds :)
5 hours of sleep and back to work.
Probably the limit on air with stock volts then. My 6800u needed 1.7V to reach 525 on air. Try a vmod?
Well.. when I tested the cards between 0C and 38C I was still stuck at 525/1380.Quote:
Originally Posted by HaLDoL
how are you doing? great to see some results from the new 7800gtx cards. Can you get your 2003 and 2001 scores to publish? Have you tried one(two?) card(s) in 2001? That 2001 looks low, kingpin gets more with one x850xt
2001SE was my first run in almost 3 years soI guess 43800 ain't that bad :DQuote:
Originally Posted by Geforce4ti4200
I just installed it and ran it. 0 tweaks used.
OPP Just broke 47K :eek:Quote:
Looking forward to your response :D
Perkam
