Got replacement X2 from outpost.com and was able to get 50mhz more (one thing is though, it seems like both core do like voltage vs previous chip. As for stepping... its exactly same stepping still CDBHE 0515RPAW) 2.65ghz @ 1.57v. I think it might be heat related problem on air for limitation I have as well as very hot PWM temp... (up to 64c I saw a t one point -_-) That is my prime 95 stable 3d stable, game stable, memtest stable setting. Memory is running 2t 4x 512mb mushkin blue 2-2-2-5 @ 240mhz 3.25v. Overall, system response time is great, gaming isn't bad at all vs 2.8ghz venice setup I had. Maybe I will get back into some cheap water solution with some left over parts I STILL had and shove it in to see how it fares.
PS) This time, core 1 is better than core 2.... figures. Core 1 actually can seem to go 2.75ghz with about 1.5v while core 2 likes to ramp up with more volt... I need core 1 from this cpu and core 2 from previous one.... that would make this 2.75ghz prime 95 stable machine on air... chuckle...
