Originally Posted by bonzer
FINALLY up and runnin, not totally loaded yet as I started playin with the ram. I have got some very interesting results so far. 1st for my setup...
Epox 9NDA3J rev 2.1 (week 4/05), heatsinks installed on all 8 mosfets, 6-cpu, 2-ram. now runnin 5401 bios. Alpha PAL 8150 with TT smartfan at (manual) 4000rpm. TT 480watt W0010 PS with PFC.
3200 venice (retail) LBBLE 0515GPBW
512*2 GSkill 2-3-3-6 econo pc3200's slot 1&2
2*WD800JB 80gig SE. IDE drives on primary M/S, not raided at this time.
Sony 16x DVD, NEC-2510 8x on secondary M/S
9800pro, ATI TV-wonder slot-6, SB-Live 5.1 slot-5, 3-com 10/100 NIC slot-3.
System booted at 2Ghz with 4b08(12-8-04) bios from factory. Vcore default was 1.40v with this bios. Disabled all unecessary on-board devices (NIC, sound, serial ports). All timing/voltages at auto for now.
Re-Booted from DOS floppy and ran update.bat for flash to 5401. Vcore now default is 1.35v...
Loaded WinXP-SP1 promptly without issue, Nvidia 5.10 drivers GART-IDE-SmBus ONLY, DX-9c ATI cat 5.4's, xp-sp1 defaults for others at this time.
UDSM 3.1 shows 2.708 VDimm as (auto) in bios. Set to 2.6 bios (2.608 UDSM) as it appears that this board does not undervolt RAM... :)
Ran memtest86 test5 only version overnight at 2-3-3-6-1t (2.6v). Looked schpanky this morning. Now runnin prime95 torture before I came to work,,, at 100% cpu max temp 37C... :D
Not overclockin cpu yet cuz I wanna lower cpu multi to 8X, htt to 3x and ramp up clock to find max ram settings tonight at 2.5(3)-4-4-8(10)-1t(2t) which will take some time.
So far I'm very pleased with the results and lookin forward to :slapass: this cpu. It appears from AMD's data sheet that the 3200 venice's have either a 1.35 or 1.40 default vcore as they define it as (variable). I'm hope'n lower vcore = lower heat = higher head-room??? time will tell.
