well guys, I just got done 3dmarking 510-2 bios, now I'm set at 9x285, using the same settings as the 2-17, except tref is now 3072 instead of 40**somthing. main timings are still 2.5 3 3 6. Not bad, about 10 more mhz on 1.45 volts for 3dmark2001 stable. Also, winflash is a very good prog to use, just don't do it unless you are running stock settings, DO NOT do it while your settings are oc'd :) 3dmark score with a vanilla 6600 gigabyte was about 19,500ish, don't remmeber exact score.
