ALEMAN WHERE U GET THIS KRAETON THAT WILL DO 270 WITH 3.35 I WAN ME SOME OF THAT SHI RIGHT THERE..oops sry for caps all
Long... the AADT uses "powerchip" chips which are only good for 200-210, bummer.
I got them from Celemine1gig here in XS. (we´re in Germany)Quote:
Originally Posted by Philosophy
Ps. the Kreton died yesterday :P.
can you be more specfic?? i mean i need more informations about my ram.Quote:
Originally Posted by Aleman
Can someone helpo me find that chart for tref that was posted herte by someone i remember seeing it a few weeks ago and now i cant find it at all, my oc seems stable at 1.95 and i wanna know how to set that in bios for stability
So has Twinmos Speed Premium (TMSP) PC3200 been discontinued? Specifically with the AA4T label. Can't find any TMSPs anywhere anymore... :confused:
I haven't seen them around in a while. I have 3 gigs of it, and only need 1gig... been trying to sell it. Hopefully my friend will realize it's worth buying from me, but he's stupid.
U welcomeQuote:
http://www.xtremesystems.org/forums/...t=61297&page=3
Originally Posted by S!1v3rB@cK_Dk
how burn in memory :P? let running memtest hours? or there is special progs like on cpus?
Hi everyone
cany you tell me if this Twinmos (not speedpremium or twister) ram has bh5 chips on it? I dont think so because winbond chips have the 2 round things in the midle of the chip and one third smaller circle at the lower right i think. its really serious.. because i ordered twinmos twister bh5 a week ago, and this 3200 2,5-3-3-8 ram came to my home today..please help
http://img311.imageshack.us/img311/3...09936rz.th.jpg
I also made a picture of the chips itself but it is hard to read, so i will write it down for you. 05120 TMD 7608FE50I (i think)
I hope you can help me
CADT + 05120 = Non Winbond (No bh, no ch, no utt) :DQuote:
Originally Posted by kriz
They are just powerchip @ 0,11u as written in the first post ;)
(Unless they have wrong label / chip prints :D )
thx wasnt sure wich id they were talkin about on the first page but i guess the last 4 letters of the P/N...
you know whats funny? i ordered a twinmos twister BH-5 and they sent me this piece of crap it can run 2-3-3-8 but nothing better..... those powerchips are poor overclocker right? :slap:
i will definately send it back
I've tried anything. But I can't get my mem over 240 MHz @ 3,2V. What could be the problem? See my pics...
http://img46.imageshack.us/img46/3654/oc39rf.th.png
No. You don't have "crap mem", lol. 240mhz @ 3.2v is good. Have you tried higher vdimm?Quote:
Originally Posted by lucius
Edit: Just noticed your timings. Have you tried tightening them? You should be able to get at least 2-3-2.
Yes, I have tried to changed the timings. As tied as they can get, but no progress. And about the vdimm, 3,2V is the max I can give with my mobo :mad:Quote:
Originally Posted by xenolith
So you say that 240Mhz is a great score :confused: There are guys that can go to 270MHz. Explain my that :rolleyes:
lucius,
First, those 270MHz+ 2-2-2-x results are done with ~3.6+. :stick:
What does your P/N-sticker and chips say? Your sticks are definately not Winbond based.
Might be Hynix D43.
here's all you need ;)Quote:
Originally Posted by largon
chips:
twinmos
05144 BH-5
TMD 7608F8E44B
sticker:
P/N M2GEJ16A8APPFF0811A4T
model no: M2GHEJ16A-PP
S/N : 514M55M31010242
PC3500 (cl 2.5) 512MB DDR-Dimm
It seems I read your reply too hasty:
2-2-2-x timings do work at 236MHz? What's the point in that pic w/ 2.5-3-3-8? Winbond chips (which they actually seem to be) don't gain freq from looser timings.
236MHz at 3.2V is quite what one can expect from these things. Put 3.4+ through them and they'll go higher - if your proc can do it.
I've tried to tighten the timings. When I stay at stock speeds there's no problem. But when I try to take the fsb up the system hangs up :mad:
If I were you I would lower my CPU multi to 9 or 10x and try again. You also are only running stock voltage to your CPU from what I see.
Lower your multi, loosen your timings to 2-3-2 or 2-2-2, and then try to hit 240fsb. You're not gonna hit much higher than 240 at 3.2v. I've owned 11 gigs of TwinMOS UTT ram, where about 5 gigs of it was the Speed Premiums. I have super first hand experience with these babies... and to be completely honest, I always ran 3.4-3.65v to them. These things love 3.4v, and definitely gain a few mhz when you hit 3.65v.
with your experience with twinmos do you know why my TMSP BH-5's can do fine individually 235mhz for one and 240 the other at 3.1v's but even if i keep the speeds and timings the same and go to 3.2v's they error out crazy in memtest? also they don't play nice together at all. is it something with the s754 dfi's? i can shoot 3.6v's to them with my psu but don't want to risk anything if they go crazy at 3.2v's.
*edit* i've played with raising cpu voltage and lowering the multi to as far as 8 to eliminate the cpu as the culprit.
If you haven't already, try putting your memory in slots one and three.
Edit: Here's a screenie of my mem tweaks with my TMSP @ 242MHz/2-2-2/3.2v:
http://www.xtremesystems.org/forums/...id=36503&stc=1
I have had no success with TMSP BH-5 in my 754.Quote:
Originally Posted by omga14
Can get sticks to run singularly @ 2-2-2 up to 245mhz max, but if I want two sticks together it's 2.5-3-3 @ 200mhz or nothing.
IMO it's a 754 issue, as the same sticks all play together in my 939 with no worries at all. I had one stick which didn't like voltage over 3.2v, but burn-in rectified that.
It might even be the 754 memory controller, because I had issues with a 939 Sempron not wanting to run 2 or more sticks either, yet my Venice's play fine.
It's a bit annoying since I love the 754..
my twinmos twister pc3200 hates anything over 3,1v , burn in wont help (n) 3,1v 2-2-2-7Quote:
Originally Posted by szukalski
Darn, my TwinMos Speed Premium PC3200 512 MB AA4T died. Ive rma it but theyve dont have anymore those sticks ( main seller - distributor in .pl ). Im from Poland, ive started to look in shop for this stick , and guess what noone have it. Also all normal TwinMos PC3200 are CADT or AADT.
My question to Alonso is TwinMos retried from building own chips on UTT chips. Is new batch of SpeedPremium's planed to market ?
