Originally posted by MrIcee
Ace:)
Pin 22 on the Winbond W3330 needs to be de-soldered or cut, then a VR set to max soldered between the board trace and Pin 22. I measured 3.22v at the board where the leg was soldered BTW, after the pin was desoldered and lifted away. What happened to me is that the leg broke off flush with the voltage regulator when I gently lifted it up to solder to it. I did not fry the board or the like...it was purely my own error in not being gentle enough.
It is basically the same mod as the ABIT BD7...except this newer version of the Winbond voltage regulator has more Pins than the previous. If anyone pulls this off successfully let me know...I started writing a guide on it....but at the moment am attempting an RMA:)
Randi:D
Thats one nasty vdimm mod Randi. I will attempt it if I like my 8RDA+ enough to keep.
