Hey peepz.
About the Vcore measuring: I don't trusted my speedfan readings (1,79V atm) so I wondered where I could measure it myself. Offcourse the dots of solder un the underside are on the same voltage as the core. But I cant reach that atm.
So what I did, is measure it on the pin where I soldered the pot on (like I saw someone do a few pages back). It said 1,59V
So I dont think thats the right voltage either. (actually pretty logical if you know how a V-mod works :) )
I'll keep looking for a nice spot, or I'll just have to turn the mobo upside down...:rolleyes:
What would 10k on the vdimm give me?
what does VR stand for and what VR will i use to do the vdimm mod? also, how much voltage will i be able to give vdimm after the vdimm mod?
VR stands for Variable Resistor. Alot of people call them Pots, which is short for Potentiometer.
You should use a 15k VR or so for the Vdimm.
http://www.xtremesystems.org/forums/...&threadid=5167
You would be able to give it all you want pretty much.
Not sure where it stops at, but you would want to STOP before you hit it's max voltage ouput.
Hey guys justed done the mod to A7N8X-E Deluxe hope its the same mod well i put a 50k variable resister for the vcore and 20k for the vdimm but when i plug the earth in the fan header she wont boot take it off and it does any ideas would be appreciated
cheers
Worked it out guys prob was the core mod took it off vdimm is working fine so will have to have anoth go at it
Vcore IC:
http://www.saunalahti.fi/~chedu/team...8x/L6917BD.gif
VSEN mod?
I put 50k vr to 10. leg with no effect (also tryed ~ 30k). Mobo doesn't boot if vcore is over 2.15V (multimeter), but I can put over 2.16V (when windows is running) and run pifast/superpi.
(Bad English)
I know I am kind of late. But will this mod work with Asus a7n8x-x.
If the layout of the board is the same, which I think it is, then yes.:) I think "-x" just means more features on the board, right?
Can I do this mod to a A7N8X-E Deluxe?
Thanks! :)
