It's always been this way :( It looks like it works... but if you look at your task manager (after you add the "Base Priority" column) D2OL.exe is running at normal priority... it should be low.
Rodzilla, is there any way to manipulate the D2OL daddy, so more ram is used?
Does this mean more production?
D2OL Daddy isn't open source... so don't go getting yourself in trouble or we all get to laugh at you and publicly stone you :DQuote:
Originally Posted by shadowing
I'm not sure if more mem allocated to D2OL would help... D2OL already allocates enough mem to calculate the current Candidate.
If anything it would be cool to find a way to make D2OL use less RAM... that way you can safely run it on a PC with limited system resources...
Ok here's my noob question :D
I'm a ex-folder (I fold for about 1year and a half) and I quitted folding for 1 reason only: internet use. I'm on dial-up and I have only one phone line at home that also serve as business line. The problem was that folding was quite using my phone line with 3 p4 rig running 24hr/7days.
So what about D2OL?? Is it the same? Did it send and receive a lot of data or not? Remember, I'm on dial-up and 1MB file is A LOT of data for me!! :dammit:
If you upload every 6 hours then it won't be too bad....you could upload only on the weekend maybe? I'm on dialup as well and it doesn't seem to bad, unless the server had gone down and i'm stuck uploading 300+cans or something. But normally it doesn't seem too bad
jjcom
Something you could do is set your quene size to 2000, and run the node offline till the weekend and then upload. What system are u running it on?
Ok then it's not the same as folding! Because with folding, if I do not upload, the work stop.
My system is a winnie @ 2700mhz with 1 gig of ram.
My Winnie at 2.6 does about 140-150 per day. If you set your queue size to 2000 that would mean you'd ned to connect once every 13 or 14 days. That upload would take a bit, but you'd only need to connect then.
Well then here I go!
hi, would like to join team, do i pick EZ installer community account? After install i then register? Is node # provided automatically? Any tips would be appreciated.I will chose 2x.for my system.Thank you.
(as you can probably tell alot of unused cycles going to waist here) DSL connection.
If you want to register your own node you have to use the personal installer.
thanks, never could find where to register nodes? had 2 icons by clock opened up & got node # saw no place to register. Rebooted now no icons but services say there running. I used personal installer.
If you used the personal installer it should have accessed you for an email address, did it do that? If not are you sure you didn't use the community one? If you did enter an email address then you have to go to www.d2ol.com and register a new user then you can add the node you created.
checked it was personal installer, must be doing something wrong i never see prompt for e mail registration
It might be that i used community install first, read your post uninstalled community & installed personal. Might be crossed up there.should i Uninstall from from program or use add-remove?
Thanks for helping, i did not remove first install properly all's good now.
What happened? What went wrong?Quote:
Originally Posted by heater918
Rodzilla, I installed community first & Helheim mentioned personal installer so i uninstalled community with uninstaller & failed to also use add/ remove programs in windows before installing personal. So i guess i stll had some pieces remaing from the community install? When i removed both properly personal installer worked fine. Hope you understand.
All is going fine now, Superdude & me are bringing up the rear end we have that covered, so other members only have to look foreward.
I get it. Thanks. What made you mistakenly use the community installer? Is my wording off? Or just too confusing?Quote:
It is a good guide if you follow it. I installed than read,definatly the user's fault here.
I have crashed & trashed windows so many times i have to get b. gates personal ok to reinstall. :bsod:
:lol: Ok... I just wanted to make sure I wasn't speaking greek or something.Quote:
1 question about installing 2 copys of D2OL.
i pretty sure of how to except the part of creating new (folder?) in directory labled D20L2. Where to put it. Is it program files.
If you are just installing D2OL with the stock/official installer then you can create the Dir anywhere you want. And just install D2OL to that lo-cal.
ok,i can do that. If i have 2 is it right that i can run 1 all the time & 2 when i'm not using comp.
You can use both all the time. They are set to low priority so as soon as you start using the PC D2OL moves out of the way and you get all the CPU cycles you need. Be sure to use D2OL Daddy too.Quote:
Once you stop using the PC D2OL will kick back up to 100% :up:
If you have the .NET framework installed you can use D2OL XtremeWatchDog instead of D2OL Daddy as well. :D
I have .NET for Ghost 9, is there any benefits of Watchdog?
I have so many questions because i will be reinstalling in next week or so and i would like to get XP & my basic programs installed such as D2OL so i can make a basic drive image before i load graphic drivers and other app's.
