http://users.pandora.be/smolly/Phase...inwerking1.JPGQuote:
Originally Posted by brechtvm
Custom phase-change ;) cpu-16°C stressed @2840 mhz :D
nice...Quote:
Originally Posted by Smolly
but TOO extreme for me :p
just gimme my 2.6ghz (stock = 2.4ghz) and i'll be happy :)
greetz :banana:
hi! i have the k8n..
but... can i use the k8n-e bios 1006?
and the ddr booster start? i have the new twinmos 1a4t that use a chip similary the winbond bh-5....i need the ddrbooster by ocz ...
I don't think you'd want to use a bios designed for another motherboard...
the layout and pcb is identical..
:rolleyes:
With what setup was this?Quote:
I have the same Proc and (2*256) 512MB PC3200 Twinmos and get these results.
What cooler do you use? With my Arctic Silencer64 my temps are 42 degrees @ idle and max 57 degrees @ 100% load.
I recently got an asus k8n motherboard and the highest I've been able to OC my cpu is 2.7Ghz. I think the bios is the issue. Since it's similar to the asus k8ne, I'm considering trying the 1006 k8ne bios as a last resort. Before I do, does anyone know of any new or modded bios for the asus k8n that fixes stability problems at 270-300 fsb? (I'm trying to reach 3ghz) thanks...
i can't reach 2.6ghz stable :(Quote:
Originally Posted by Python
superPi 1m > stable
Prime95 torture test > not stable...
i wrote down my core info :
ADA3400AEP4AX
CBASC 0414XPMW
9545842D40453
i think i have a bad oc cpu :(
if you can talk in dutch > pc.naar.be
there you'll find all info about my pc config....
(chose the amd3400+ section)
greetz
look this: http://img177.echo.cx/img177/156/28007on.jpg
is that your cpu ?Quote:
Originally Posted by Poy
Can you please give me the core info...
en français: c'est ton processeur ?
Voulez-vous me donner l'info de votre processeur ?
c'est écrit sur votre processeur :
example:
ADA3400AEP4AX
CBASC 0414XPMW
9545842D40453
(c'est la mienne ;))
hi guys. does any1 still use this mobo ? :rolleyes:
Was using bios 1011 then 1012.beta, but they set ddr400@333 when using 2 dimms :eek:
got back to 1009 but manual settings won't work correctly (setting cas 3 when i put cas 2.5, when i put cas 3 it freeze), so way back to 1006... but having serious problems, like is stable with 250*8.5x, but getting errors with 250*8x :( and can't get this gskil F1 (TCCD) 2*512mb above 260fsb (even with ldt 2x) ... strange mobo :stick:
what bios do you guys advice?
Hmmm after readings almost 8 pages of the K8N oc' experiences.. i would like to add mines.
I bought this motherboard a while ago (1 year) together with a S754 A64 3000+ that runs at 2GHz.
3Days later i just pushed the HTT to 240 and the memory at Default timings / 83% devider. The cpu hits 2.4GHz now.
Last sunday i tried to remove the IHS, which succeeded, but with some trouble :P I accidently broke a capacitor while i was trying to cut the IHS from the Chip. Second, the size did'nt fit anymore, meaning my cooler woud'nt fit at all at the CPU.
I had to make some serious adjustments and hope the CPU is still alive. I took a saw and made my bracket that is on the K8N, a little bit lower so if the cooler would be placed it would make contact with the core. After testing and testing i finally hitted the power button and it still worked! Thought i was going to miss my 130€ Cpu for a moment.
http://members.home.nl/lism.1/k8noc.jpg
I did not do really much for it to get it at that speed. Lowered the MemoryDivider (83%) and hitted the 240HTT (equal to 200MHz memory speed) It's Prime95 stable.
So. My last thing i'm wanting todo now that the IHS is gone, is start playing with some peltiers. I still wonder what the TDP of a OC'ed CPU would be, not that i'm installing a wrong TEC lol...
I have'nt updated the BIOS yet (1.04 i think) but i see it's at 1.11 now :P Time to bring back a floppy drive... I've also tried various ways to get the HTT at a higher value, but above 245 it chrashes, even if i set the HTT MP to 3,2 or even 1x.
It looks like a lack of chipset power here. It won't go any further no matter what i do. Still, 240HTT with a Clock of 2.4GHz , is high :)
http://tweakers.net/ext/f/2b4dc6d7c7...46f49/full.jpg
Bad image quality, but the red marker shows the broken Capacitor, yet the CPU still works and does'nt show any errors...
Is there a bios version out there that supports more than 300htt?
I can do 300*8 on a Ml30 , but that only yields 2400mhz and this Turion definitivly can yield much more.
I know this is an old thread but wonder if anyone has installed bios 1011? AI overclock works @ +10%, no problems. Too bad stand by no longer works with this bios. I wonder what o/c's you guys get w/ stock fan.
my AMD is stock cooler, and idle temps is 38C, 45C load (cnq, q-fan enabled).
