Talk is very cheap:DQuote:
Originally Posted by JacobHansen
OPP
OPP
Originally Posted by OPPAINTER
Hehe Amazing clocks OPP :stick:
:toast:
" I am picking one up tomorrow.
I'll PM you the link to 3700MHz
__________________
Visit ***Liquid Ninja's*** Forums
Come and join the folding team and see if your rig can Handle "
Do you recognize this ;) ? hehe.. Your absolutely right.. Talk i Cheap.. :D
You know what I mean then:DQuote:
OPP
Bahh ;) - Yeah.. Good numbers btw..
I'll see if I can get you that 3700 screeny next time I fire the rig up. Havn't tryed yet.Quote:
OPP
Nice scores Opp :banana:
that is weirdQuote:
could it be a defective fx55? rma time?
Hey OPP
Did you try installing win2k on air then switch to phase-change? :)
AMD is not going to RMA a chip just because it has problems when you run it it at -90C :DQuote:
Originally Posted by Geforce4ti4200
OPP
I had perfectly fine w2k OSs already installed, I switched from my FX-53 to the FX-55 and Windows went nuts.Quote:
Originally Posted by Pejsen
Then I tryed to install w2k clean. Couldn't do it, it would go blue screen on me.
2003 and XP has no problem with the chip.
OPP
Hmm sounds very odd :confused:
But 2003 will atleast give ya some great SuperPI :D
This is beginning to get outa hand
Once again....very nice Opp
OPP's the man :D :toast:
Outrageous clock on that FX! Where's 03 GT1 at now? :D
And that is something that seems more than silly - OPP's got clearly the highest car hi if we exclude ricky/pedro score and thats how it should be.Quote:
Hes only 4fps behind ricky/pedro in car high, but has lower ram clocks though
I mean 3570 and 178 CH vs. 3391 and 182 CH?? and same goes to lobby scores. ricky/pedro - what's the trick there? how much do you score at default clock or at 3G?
Having slight problems catching your score in 03:DQuote:
Originally Posted by macci
Gunna try some more today.
OPP
macci: pm sent
Can't give you the 470, can give you 466 though, and new champ of 3D03.Quote:
AMD takes it with 18522 :D
OPP
Nice! :toast:
hmm, you state "260x13.5= 3505MHz", and "260MHz,,2-2-5Cas2"
i was under the assumption that the .5's always gave lesser ram speeds, such that yours would be 3505/14 = 250mhz, not 3505/13.5 = 260mhz... or is the k8n neo2 immune to this bug? (i didnt think it was...)
anyways, awesome job taking #1 with a64 in all three. ;)
I have no clue what the ram officialy does, it says 260 in windows, so what:DQuote:
Originally Posted by pik-ard v1.1
OPP
heh... still #1... but your ram was running 10mhz slower then you though. ;)
I don't think it's 10Mhz slower. I think it's more like 8 from my testing.Quote:
OPP
