I don't think you can call me a new folder. I was part of DF until it shut down and then had a problems with the java installation.
I am new to D2OL though.
Start at the "start" thread...Quote:
Originally Posted by eddy
http://www.xtremesystems.org/forums/...ad.php?t=43195
There are tons of links to stats pages there. You may be interested in DSpy to keep tabs on your computer's progress. Personally I've never used it, but there's been plenty of people who have and been happy with it.
:toast:
Nah i wouldnt fold under my user name. I'm sure my school would like to do it under their own name un the XS team. After all, the installation is "XS customized", and knowing the administrator he won't care too much about the name it's under, as long as it's for a better purpose.
I'll talk to him tomorrow and see how it goes :)
If he doesn't seem like he's going for it, suggest a little test trial on 5 to 10 computers before he comes right out with a "NO!". ;) That way he can see for himself that it doesn't affect machine performance.
That would be really sweet if we can do this! :up:
Just joined for the fun :)
With the system in sig :toast:
(joined under the name DenusJ)
But now I would like to do 2 things:
1. Change myself to individual in XS team
( :confused: :shrug: )
2. Add 'Hers' computer to the gang.
HELP PLEASE!?!?!?
so that means your under the Comunity node? right?
How I do things:
1.) Download and install the D2OL offical installer
2.) Regsiture under an email address (remember which one) and let it download some cans
3.) http://app.d2ol.com/memberServices/createMember.jsp
go there and use the node number in the upper right hand corner of the GUI and the same email address
4.) get under the Xtreme system team and get to folding :D
5.) Run the D2OL installer on "hers" and use the same email address as before. Let it fold
6.) sign into your account on D2OL.com and add her node number. Remember what it is, it will give you a list of nodes that are regisutred under your email
theres other ways you can do this, but this is how i like to do it. Theres the one where it runs in the background with Rodzilla could probly help you out there.
jjcom
I assume you meant to use the community installer and help out the team :up: Glad you liked it enough to create an account and join the team under your own user name! That's exactly what the community account is there for... give the project a spin and see if you like it!Quote:
Originally Posted by mad mikee
.:NOTE:. I know this looks like a lot but I made it wordy to eliminate confusion... it's really simple!
To make your node, created by the community installer, stop crunching for the XtremeSystems_Community account, and start crunching under your own personal account:
You need to remove the node.prp which holds the node registration and create a new node with your registration info.
1.) Stop the XS_D2OL Service from running so you can make the changes.
Go to the service manager (Right click on your My Computer icon on the desktop and select Manage. At the bottom you should see Services...) Stop the XS_D2OL1 service. (Repeat for XS_D2OL2, 3, and 4 is you used the multiple node installers.)
Now go to the task manager and stop the Gridwin.exe task(s) (or Dockwin.exe) Do it for all of them if you used a multiple node installer (There will be multiple DockWin or GridWin task running if you did)
The D2OL Agent(s) is now stopped.
2.) Now remove the node.prp file from the "C:\XS_D2OL\D2OL1\D2OL\res" folder
This will unregistered your node from the XtremeSystems_Community account. You will then be free to re-register your agent under your own account.
Now go to the "C:\XS_D2OL\D2OL1\D2OL" and open D2OL.exe. This will start the D2OL Agent in the sys tray...
When you start the D2OL.exe file it will ask you to register the node... Use your e-mail address that you already have an account for, or plan to use to create an account. Use the same e-mail for every node you ever register. !!!***USE A REAL E-MAIL ADDRESS THAT YOU HAVE ACCESS TO***!!!
Repeat step 2 if you have any other nodes on the system created by a multiple node installer. Substitute the path to D2OL.exe and node.prp with "C:\XS_D2OL\D2OL2\D2OL" and so on for multiple node installers.
3.) If you haven't already created an account you will need to do so now. The following instructions assume that you do not have an account.
Take note of the node number(s) that were just created when you entered your e-mail for registration. To do this:
Right click on the D2OL sys tray icon and select Status. At the top select Statistics.
Here you can see your node ID and your e-mail address.
You only need to know 1 of your node ID's for registration. The rest will be available to add once your account is created.
With this information you can now create an account.
Go to this page and create your account. http://app.d2ol.com/memberServices/createMember.jsp
Enter the e-mail and a node number that you have registered.
The node that you used to activate your account will be automatically tied to your user name.
If you registered more nodes you will be able to add them by clicking on the "ADD NODE" button at the bottom of your "Team - My Home Page".
You should be ready to rock and roll!!!!!!
.:NOTE:. Any points that you have contributed to the XtremeSystems_Community account belong to that team account. It's impossible to separate them out.
I'll enter into the top70 of the team in a short time :D
I'm using this program since last week and i did 1066 candidates. Is this a good mark or not?
C'mon, we should be 3rd at the end of the year! Let's help! :D
For only being active for 9 days! And on 1 rig :up: That's a very nice contribution!Quote:
Originally Posted by BeSaiD
here joined a little late just figured seti isn't where i am at any more
:welcome:
Well I guess I can add my name here too. Startin out slow.
Welcome, officially. I've gotten to know some here, but it is good to have someone with you who goes back much further. Glad you're here, PU! :)
Originally Posted by Plum Ugly
That's a sweet AV! :lol: a purple monkey! :up:
Glad to have ya around! :up:
you should grab a sig at the sig thread, they are pretty cool!Quote:
Reporting.
just joined XS .
I have two nodes working but want to merge them under one name but i cant do that for w/e reason (i used the same email address for both the clients)
Anyone wanna guide me thru this. I know my Athlon can run two clients :D :rolleyes:
Excellent! Welcome to the team! Glad to have you with us.
I'm sure one of the more knowledgeable folks will be able to help you in the later AM hours, once they wake up.
find the node.php file in the D2OL install folder. Then basicly, put that file on another install of D2OL and overwrite he first one.
jjcom
Merge the 2 accounts so the nupdes are under one account.
Log into the account you want to keep here http://app.d2ol.com/memberServices/memberLogin.jsp
I'm new...
I'll be moving along a good deal faster once my PC-DL and IWTs get in this coming week :)
yep, i'm up and foldin now :toast:
just joined today
Welcome to the team, shmaa !
glad to have you crunchin' with us. :)
Scott
