I have been able to do 220 @ 2-2-2-5 with 2DIMMsQuote:
What does the Chipset voltage actually do?
Poki 250 "seems" stable, 255 gives errors in PI.
Check pic if you want some info that you can use.
Zeus i need 1.8 volt to go beyond 280 i think.
Win wont boot else.
And really high fsb and low chipset volt gimme the "drive array" if i remember correctly.
@Ubermann
Thank you for your efforts. I appreciate it.
Best Regards,
pokipoki
i use 1.6v with my board.. doesnt help to give it more.Quote:
Originally Posted by Ubermann
I just tested 250 @ 2.5-4-3-10 with an 8x muliplier. I have figured out that it is my CPU that is causing my system to be unstable. 250x8.0 gives me 2.0GHz and I survived MemTest-86 and SuperPi 32M and completed it in 39m 44s. First time I have ever ran that. Not sure if that is good or not. I am guessing it isn't. But atleast I got 250 stable now with 2 DIMMs. I shall try for alittle more.
Here is my 250FSB Screen.
Going to try for 2.5-3-3-10
I do run 1.8 volt on cpu to get it stable near 2.4 gig.
This cpu isnt good at all for overclocking.
Its seems to be good for high FSB only.
Whats max you got in 3Dmark01 with that ATI ? (unstable or whatever)
*Edit is it in the sig ?*
22,644 is the highest I have ever gotten.
I have gotten 7,311 on 3DMark03 @ 441/375. Those clocks are the same for 3DMark01SE. I can't even get 3DMark01SE to even run anymore. It fails to load.
Reinstall windows maybe =)
I do it ones every week lately i think.
Nah I just reinstalled it. I got 7,157 on 3DMark03 with only 2GHz:D
I dont think i can beat that with mine =(Quote:
Originally Posted by ugp
Your 9800 Pro can do alot man! What do you have it clocked at right now? I bet you can get 7k easy. You just need to tweak it alittle. My 9800 Pro I had will do 450+ on the GPU and I can't remember on the Memory. But what you should do to it is take an AMD Barton Heatsink and slap it on there. Use zip ties. It works. That is what my friend Jeff has going on with my old card and it works nicely.
I slapped one of the sensors from my case and my RAM runs 37C or so during normal usage. (ie. Web browsing and chatting). It that about right? Can you guys post what your temps are on yours?
EDIT...my RAM is @ 250FSB right now...
Tried all "Write cas latency"
Seems like Auto,1 and 5 works.
The rest gives blank screen.
But killing powersupply and tapping Insert key will take you back to bios instead of clear cmos.
Never thought about it before =)
Yeah my friend showed me that and it makes the board BOOT safe settings and then you can go into BIOS like normal and all your settings are still there. Because I have a lot of sh*t disabled and all. And it is a pain to go back and do it all over again each time.Quote:
Only works on ps/2 keyboard it seems.
That I had noticed as well. I have the Cordless MX Duo set but I have both PS/2 plugged in instead of just the USB. Seems to work alittle better that way.Quote:
OK, things are looking a bit better now as far as my setup goes. I installed a 90cm fan to blow on the DIMMS, and I re-flashed my bios with the 10/05 version. I went ahead and heatsinked/fanned any mosfet that was getting warm as well. So far I can get 243~245 stable with 2x512 modules running at 1:1 with my multiplier at 10. I can get 250, but it isn't completely stable. I am pretty sure if I play around with the RAM settings some more I can squeeze a little closer to 250 stable. I went ahead and flipped my XP-90 around as well so that the heat pipes face the DIMMS and get some of that RAM cooling goodness too. I know I changed a lot more than one variable here, but whatever it was has sure improved stability.
LOL! Damn you have done alot to it...what components are you using with your DFI? Please post I would like to know...
Sure, no problem:
AMD 64 3400+ CG
OCZ PC3200 Plat Rev2 1 gig (obviously :D ) cooled with 90mm fan
XP-90 w/90mm Panaflo
Vantec iceberq copper NB chipset cooler (using the smaller copper sinks on the other mosfets cooled by a 70mm fan)
550 Watt TTGI SS w/dual 80mm fans
120mm Panaflo intake fan
120mm Panaflo exhaust fan
80mm side intake fan
Got any pictures? And you should be able to get that RAM stable @ 250. Look at mine in my specs...tell me if you can tighten the timings any? Or is you can improve bandwidth with any of the other settings this board has to offer...
Are there any 1gig sticks of this ram ?
Not that I know of anyway...I am not sure if they are going to make any. I do know 1GB sticks do not overclock worth the sh*t! :p:Quote:
