Thanks. Not bad for a 219MHz FSB, but I have not updated that score since I got my Mushkin 2-2-2 special. Might do it tonight.
Got a link for that Gigabyte BIOS?
Within the archive mate :)Quote:
http://paddy007uk.freeservers.com/VG...ga%20flash.rar
Thanks Michael.Quote:
:toast:
I take it this mod is only for the VIVO versions of the X800 Pro??
Yes, ViVo only.
My Club3D ViVo arrived 1-2 hours ago and is now running at 16 pipes!
I even have the XT sticker upon the cooler. ;)
Viva ATI!
I bought a powercolour x800 pro and it wasn't a vivo and it worked. the actual board had the rage chip and so on, but the product that I bought was an x800 pro
That's Correct.... they all seems to be XT cores with 1.6ns DDR3... :)Quote:
I'm having troubble :(
While benching my system hangs. Screen goes blank and goes to standby. I have restart the whole :banana: :banana: :banana: :banana:.
This happens after a while. Maybe it's heat-related?
I have it running @
GPU: 472
MEM: 450
:o
Why is this happening?
I flashed fiorst with the Gainward bios, then with the ATi X800 XT one.
HAHA! :D
Problem solved!!!
I flashed back to my X800 Pro BIOS. Clocks went back to normal, no more unstalility, i can overclock again and all 16 pipelines are working!
Just playes FarCry online for 30 minutes.. didn't freeze once! :D
so your running an x800 pro bios and still have all 16 pipelines?
Yes! :toast:
maybe that was the problem ;) :rotf:Quote:
funny typo :D
interesting to hear the 16 pipes are working even when you flash back to a pro bios.
can you oc better with the pro or the xt bios?
I just bought a PowerColor X800Pro w/ VIVO...so hopefully it will flash just fine.
Do any of you guys notice a heat issue when doing this mod? I'll be on stock cooling for a while, so I don't want my card to heat up badly and render it useless.
funny typo :D
Sorry bout the typo's ;)
While using the XT BIOS i could not overclock as much as i could using the PRO BIOS.
I got over 57.000 in Aquamark 03 with the PRO and 16 pipelines. :)
With 60 pipelines you may play farcry at 500 fps but you need a 1 kW power supply! :)
Opps! I ment 16!
hehe..
That brings up an interesting question. Has anybody tried the Gigabyte BIOS on a non-VIVO card that has been modded?:confused:Quote:
tried it on a moded Club3D Non Vivo with moded bridge.Quote:
No go :( :upset:
It is a no go because the non vivo pro uses the AA chipset that is different from the AD used by XT and VIVO.
It has a different asic code and any piece of software can recognize that it is not an XT card.
What about the cards that were modded successfully that are not VIVO? Do you think they lied or do their cards have the AD chipset?
No, first pro core releases (AA) have not any further protection than the lasercut.
Latest GA, every GB and GC cores seem to have another protection that controls the GPU I/O addresses where there is the asic code and if someone try to change it, it is suddenly restored the original one.
I just tried the Gigabyte bios on my nonVIVO Pro.
flashing went well, but pipes are still 12 :(
I have Overdrive feature and coretemp reading available now.
Recognised as "R420" with 4.7beta Cats.
215RAACGA11F
GC0018.1
0421AA
21st week!
I have this video card:
http://www.newegg.com/app/ViewProduc...102-364&depa=0
Its a vivo
I tried the rx80x256v.f1 biod with this command:
gvf11 -p -f rx80x256v.f1
no go...
any ideas, or something im missing? Do i have to install new drivers after the flash? help pls
The flash works i got the xt speeds, but 12 pipes
If the card in the picture is the card you actually received it's not VIVO, but TVO.Quote:
Its a vivo
no go...
Be careful RMA'ing to Newegg. They are ba$tards!:mad:
Here's a screenie of my current setup.. Do you think i can get the clocks any higher?
What do you have them set at? I think it's verry odd that some can clock way higher than others on the same card!
Notice the 16 pipelines.
(My card is a sapphire x800 pro if that is of importance...)
At stock volts (1.3v) you should be able to run around 540/580 on average. At 1.4v it's more like 570/610. These are averages plus or minus 5-10 points, on stock air.
You have to play with it. If memory's too high you'll get arties and if GPU core is too high it will freeze.
