Problem with P67 Sabertooth
Hello XS!
I recently got my P67 Sabertooth board and replaced my previous cheap ASRock P67 with it. Processor - i5 2500K - stayed the same, just swapped boards.
Now I'm having real pain-in-ass problem:
When I try to OC my 2500K in BIOS, I cannot increase the CPU Ratio. When I try to enter any number higher than 33, it automatically flips back to 33.
I'm using latest BIOS from asus official site - 3302. Wanted to try older BIOS, but cannot: EZ Flasher says "Image outdated".
Then I downloaded AI Suite from ASUS official Sabertooth P67 page to check if I can OC it in Windows. This AI Suite did not have any OC software included :O OK, downloaded AI Suite from Maximus Extreme IV page and this one included lots of more stuff - including TurboV EVO that I needed.
But sadly, this is the picture I get from it:
http://www.upload.ee/image/2774617/turbov.png
- So no overclocking possible in windows either. I have all latest drivers installed.
On previous board this same proccessor was running on 4.6ghz 24/7.
Also, I got some other p67 sabertooth users post pictures of their BIOS settings. What I noticed was, that they had options like "Turbo Ratio" and "By All Cores" with the SAME bios version, I don't have these and have only "Turbo: Enabled/Disabled" instead of those :?!?!?!?
I have tried to re-flash bios with same version, cause I cannot flash any older version. Tried "Load optimized defaults" several times and even used jumper to clear cmos after flashing. I have no clue anymore what to do.
Any ideas? RMA? :(
Edit: Also tried to disconnect all devices - hard drives etc. Just left keyboard and video card connected to motherboard. Did not help. Also tried another RAM, did not help.
My configuration (even tho what should matter is motherboard and cpu only):
Asus P67 Sabertooth
Intel Core i5 2500K (same cpu that OC-d just fine on ASRock P67 Pro3 SE)
2x4GB Kingston HyperX DDR3 1600mHz CL9 (tried single Patriot 1x4GB 1333mhz also)
2GB MSI HD7850 Twin Frozr III
Chieftec 650W APS-650C
