There is nothing wrong with this board. I am running 4.8GHz at 1.375vcore and my memory at 2133 with 1.55vdimm and this system is rock solid.
Read
THIS thread and set the board up like Englishman.
BIOS 1.10B3
Overclocking
CPU Base Frequency [10kHz] [10000]
Adjust CPU Ratio [33]
Adjust CPU Ratio in OS [Disabled]
Internal PLL Overvoltage [Auto]
EIST [Enabled]
Intel Turbo Boost [Enabled]
DRAM Frequency [DDR3-2133MHz]
Extreme Memory Profile (X.M.P) [Disabled]
DRAM Timing Mode [Link]
Spread Spectrum [Disabled]
VDroop Control [Low VDroop]
CPU Core Voltage [1.37]
CPU I/O Voltage [1.05]
DRAM Voltage [1.6V]
System Agent Voltage (SA) [Auto]
CPU PLL Voltage [Auto]
PCH 1.05 [Auto]
DDR_VREF_CA_A [0.75V]
DDR_VREF_CA_B [0.75V]
DDR_VREF_DA_A [0.75V]
DDR_VREF_DA_B [0.75V]
Overclocking/Advanced DRAM Configuration
1,9,10,9,27, the rest on Auto
Overclocking/CPU Features
Active Processor Cores [All]
Limit CPUID Maximum [Disabled]
Execute Disable Bit [Enabled]
Intel Virtualisation Tech [Disabled]
Intel VT-D Tech [Disabled]
Power Technology [Custom]
C1E Support [Disabled]
Overspeed Protection [Enabled]
Intel C-State [Enabled]
Package C State Limit [No Limit]
Long Duration Power Limit (W) 120
Long Duration Maintained (ms) 1000
Long Duration Power Limit (W) 140
Primary plane turbo power limit 0
1-Core Ratio Limit 48
2-Core Ratio Limit 48
3-Core Ratio Limit 48
4-Core Ratio Limit 48
Settings/Advanced/Integrated Peripherals
All SATA set to RAID or ACHI
Settings/Advanced/Wake Up Event Setup
Resume from S3 by USB Device [Enabled]
