Originally Posted by GullLars View Post
If you insist on spamming one application, try making a "multi-thread" batch setup, make one batch launching 10 other, and then have those 10 launch N instances of the program each, like 30 for a total of 300. Should be interresting to see if the QD skyrockets.
I stilll suspect the ML1231 reads every FF instance afte the first 2-10 from cache, and thereby get cache speeds instead of disk speed, so you'd basically be benching the RAID controllers caching performance.
nowhere in that do i see gullars saying that it is no better at real apps. not once does he say that. he just says your taking advantage of cache performance. not that it is bad and he is not belittling you napalm. neither does he say the 1231 is a "stinking pos".
