Is it possible that the ones that have the cold bug here are the ones who burn test their card before fitting the water cooling?
Did anyone who bought their second card because of the cold bug, burn test their card before fitting the waterblock? I'm suspecting that the 2nd one worked fine simply because you went water immediately, without burn testing it.
My theory is that the burn test heated the chips too fast, too hot, that it would simply break the internal connections when it does cool down. When it heats up again, it'd expand and reconnect. Thus you got connections that'd only connect on high temp.
Is this too far fetched?
