http://www.aquatuning.co.uk/product_...ing-Pumpe.html
This combo works fine and dandy in small Stacker-type cases because it's easy to install, fill and bleed. Honestly I like this idea.
The first link is for the Radiator on it's own,no pump you supply your own 350 or 355.
The second link is for the radiator with the pump included which is a 350, as far as i know by looking on swiftech's site the included pump is allways a 350.
I have an i7 980X, two GTX 480s and an Antec 1200 case. Would the MCP320-Drive be good enough for this CPU and the two GPUs, for running relatively high overclocks? (ie. 4.4GHz for CPU)? Air temps for my 480's are sucking bigtime, can't overclock it much at all without the temps going into 90s on full load and 100c in Unigine Heaven.... so I'm really looking for something better without too much hassle or expertise required. The MCP320-Drive seems appropriate?
Also can I use an EK Supreme HF with this setup? Or is it better to stick with the Apogee XT?
EDIT: Actually is it feasible to buy TWO MCP320-Drive's, one for CPU and UD7 northbridge, and the other for my two GTX 480s? Is that a good idea? Can both be mounted on the back of my Antec 1200 or can't you do more than 1?
awesome product! I've been having a bit of a hard time last couple weeks trying to plan out 2 loop vs 1 loop ideas for my CPU/GPU blocks. This makes life so much easier now.
Prospective buyers...... Give it a go, you wont' be disappointed. Just remember that orientation of the radiator is somewhat limited because the res and pump are integrated into the unit. The Swiftech site shows all of the approved/non-approved orientations. I've been very happy with mine. Head pressure and flow from the MCP 350 is good and it is a quiet little pump. I think the fact that the pump mounts to the radiator and creates an "aftermarket" top so to speak, really helps the performance of this system.
you can daisy chain additional radiators and pumps to your heart's content. about the only consideration is that the mcp350 always has to run primed since it's a non-priming pump.
Yeah, I'm just a graph freak and like seeing test results. They probably don't want to show it because to test it...you'd have to include the radiator as part of the package. The radiator itself will have pressure drop, so the net test result would be worse than a pump by itself.
That's not to say that it's worse than separate components though...just one of those hard to explain things where you have a combination of pump PQ performance that's already reduced in performance by a radiators restriction. That's my guess anyhow.. They could at least compare using system flow rate I guess, but that too would be a bit of a mixed bag of things. Some people would probably want you to test with an aftermarket top, etc....
I would guess it's probably better than a DDC with stock top but worse than one with a good aftermarket top. Difference pretty marginal though and not enough to really worry about.
