sorry installing new mainboard and reinstalling windows takes time :p:
its fine, i am just impatient :worship:
ok im going to forget the maths that 16 years im learning.....
1 IO/s is 4kb/s
20094,53 is 257,60Mb/s????????????
lol ok just do the equation right..... if 1 OI/s is 4kb/s then 20094,53 IO/s
how many Mb/s are???
simple..... x= 20094,53 * 4 = 80378,12.... kb/s then?????????????????????????????????????????????? ?????????????????????????????????????? how the heck got 257Mb/s?
LOL i think he is trying to say that the numbers dont add up...that was a 4k random write test? because that profile 'fulltest.icf' that was posted is 4k random write test. i was wondering the same thing, is that the test you ran?:confused:
Ya it was the test I ran. Downloaded it this thread.
http://www.ocztechnologyforum.com/fo...hlight=iometer
wow impressive results! cant wait to see a 4k random read or just sequential of anything lol...any feedback on access times, could ya tease us with that? a pcie device it should be spectacular
The default test for that iCF is "All-in-one" - all possible 4-64KB, 0-100% random, read/write 0-100% dispersiion. Check it.. it is not 4K random write test.
@alfa-thanks! i had a feeling i was missing something, that is why i kept asking., i was running the 4k random write file on there!
http://i18.photobucket.com/albums/b1.../Capture-6.jpg
Got everything installed. Will run some gaming/photoshop tonight if work isn't too busy.
lowfat
Could you please run CDM 3.0, it includes 4K QD32.
(CDM 3 it's still in beta but you should be able to find it)
Link to post on forum where you can safely download the 3.0 Technical Preview.
Hm, why is seq. write so bad? :confused:
Now IOmeter 4k 100% random 100% r/w 64 threads
and FC-Test (create, read, copy) with my big-pattern.
Please not less than 3 runs per create/read/copy (for exactly results)
example: (the first 9 results 2x MTRON Mobi with ARC-1210 - the rest Solidata K5)
http://www.abload.de/thumb/hc_529x5fj.jpg
CrystalDiskMark 3.0 Beta 2 http://release.crystaldew.info/CrystalDiskMarkSetupBeta @ Low - please only 1000MB or 2000MB filesize ;)
How much did you pay?
And how much are X25-Ms in Can or USA?
Yes it uses ram. The amount used depends on the formatting block size.
http://i18.photobucket.com/albums/b1.../Capture-8.jpg
Ok, more to the point is read :)
Please read #190 once again ;)
I create a pattern with 5GB testfile for you ;)
Wait a moment...
edit:
2 patterns (4k - 100% random - 100% write/read - 10 minutes - 64 threads - 5GB filesize) http://filestore.to/?d=74677AED6
Please click your username at "Topology" and choose your favoured partition in "Targets". Donīt change other parameters!!!
Here is the read test. Will do write tonight
http://i18.photobucket.com/albums/b1.../Capture-9.jpg
May I suggest an IOmeter setup to test this card?
100% read 100% random 4KB, 5 sec ramp-up to avoid latency spike at start, 1-2GB test area, 1 min runtime. 1 worker, and following queue depths:
1, 2, 4, 6, 8, 10, 12, 14, 16, 18, 20, 24, 28, 32, 64, 128, 256.
This will provide data for making a depth analysis of how the card handles random read at different queue depths. I have done simelar setups to analyze other SSDs, and it gives good graphs.
If it's not too much work, the same setup with 100% write would also give great info.
If you still feel up to more benching after that, a run with 66% read will how how the card handles mixed read/write .
I quote myself from the thread Storage > LSI 9211-8i: (partial quote)
So like i said in the other thread, I think ioXtreme will do great at the IOPS+IOPS/[average accesstime]. The reason for making a graph with those parameters is it weighs heavy on accesstime, wich is the great strenght of SSDs, and also level of parallell architecture and controller technology to allow scaling IOPS whitout gaining too much latency. But it also rewards high IOPS at high queues even with higher latency, wich the IOPS/[average accesstime] doesn't, and I think most of us agree that high IOPS throughput at high QD is valued despite higher accesstime, though lower acesstime is better.Quote:
As an example, here is Test 1 with almost the same parameters done on an x25-M connected with eSATA to a laptop. I know this is a bit different from what we will be testing, but the analysis method is the same and should bring usefull data and graphs. Benching data provided by Anvil, I've crunched the numbers.
Link to benchmark screenshots. (click spoilers to see screenshots)
Links to graphs generated from data:
IOPS by QD
Average accesstime by QD
Max accesstime by QD (this one went bad because of eSATA and craptop)
Snapshot of the spreadsheet used for first 3 graphs
And then the complicated and even more interresting stuff:
IOPS/average accesstime by QD
IOPS vs IOPS/accesstime by QD (2 competing graphs)
IOPS + IOPS/accesstime by QD (2 stacked graphs)
And finally link to excell 2007 spreadsheet with all raw data typed in, calculations (a few notes) and graphs. (XS wouldn't allow me to upload .xlsx, so it put it on a fileshare service)
Personally i love the last graph here with IOPS+IOPS/accesstime, as it depends on both high IOPS with simultaneously low accesstime for high scores. I bet ioDrive and ioXtreme will own at this particular graph, as they are designed for low latency and with massive parallell design.
@gullars youshould make a profile to do the testing that you need then we could just show you the results on the spreadsheet i.o meter creates!
oh wait i guess you cant put that all in one profile!
