Gentlemen, we have proof of life!
And they're twins!
The Towers of York have arrived, Behold!
[IMG=http://img27.imageshack.us/img27/5177/compressortwins.th.jpg] [IMG=http://img27.imageshack.us/img27/9008/compressorlabel.th.jpg] [IMG=http://img11.imageshack.us/img11/5134/compressortwinsvertical.th.jpg]
I finally found the documentation for these units.
[IMG=http://img15.imageshack.us/img15/8163/matsushiacompressortabl.th.jpg]
They are a pair of K-Series Matsushi+a rotary compressors. These units appear to have a lower capacity than what was advertised. I'm not sure if I should file a complaint with Ebay or not? This was only my second time doing business on Ebay, and I don't know how strict they are about advertising correctly about specifications. These compressors have only a 19.6cc/rev displacement. I'm glad I didn't pay anywhere near full price!
Shingoshi
I am reposting this from another thread...
It may be more relevant here.
As always, click on my images to see the links they point to!
Originally Posted by
mEsUsah1
The system you are talking about is a two-stage system. You should know what you are doing if you atempt this. If the "condenser" (really a gas cooler) is to efficiant you wil have liquid out of it. But the good thing about this if you do it right is that you will have a lower spesific volume, and lower gastemperature. That means lower displacement on the sencond stage, and lower power consumption overall. It's a good idea to have a liquid seperator after the gass cooler (middle pressure cooler) to avoid a broken compressor. :) In industrial cooling this is actually a normal way to do things ;) (mainly because you will have lower gas temp into the condenser, pluss a lower power consumption)
I'm guessing you'd want to use something like this:
http://www.rparts.com/Catalog/Major_...ccumulator.jpg
So then the question now becomes,
1.) Which refrigerants are pretty much guaranteed not to condense at room temperature? R-744?
2.) Specifically, which refrigerants need very low temperatures to condense? I know that R-14 is a candidate.
3.) Should both compressors be a different size? The first one larger than the second?
4.) Could such a system function with only a single refrigerant? Or would you still need another seeding refrigerant (like R-600a) to work for the subcooler downstream from the second compressor?
5.) Could you have a combination of refrigerants all incapable of condensing at room temperature? (That seems to make sense)
6.) So which refrigerants require an even lower condensing temperature than R-744/CO2?
Shingoshi
EDIT: Sorry for repeating myself. I keep re-editing my text, and I wind up with redundant questions.
EDIT: I always learn so much from these guys!
http://www.refrigeration-engineer.co.../header_07.png
EDIT: I think this applies to this subject as well:
http://www.wipo.int/pctdb/images/PCT...gz_en.x4-b.jpg
A very interesting link from YouTube on the phases of R-744.
Triple-Point Analysis of Carbon-Dioxide
My apartment has 240V lines...
sdumper
You know whats funny...your going to pull this thing off and were all going to be sitting here eating crow :)
Good luck and glad your compressors came in. Is 220v going to be a problem for you?
I found that out from the maintenance worker here. The electric heaters all use a separate 240V line to operate them. So I shouldn't have a problem with the current.
And I'll try not to gloat too much while everyone here is eating crow. Because the fact is, I'll have to eat some myself. I'll still be making mistakes along the way. So maybe we can just have a big BBQ and eat crow together!
Shingoshi
EDIT: One thing about the gas coolers mentioned above. I think I will be using four of them, all mounted vertically to the bottom of the case, so that their inlets/outlets are at the top. That will effectively prevent any chance of fluid coming back into the second-stage compressors. Here are the pics of these units again, so you can see what I'm talking about.
[IMG=http://img38.imageshack.us/img38/6015/fmic3210031.th.jpg] [IMG=http://img38.imageshack.us/img38/3728/fmic3210036.th.jpg] [IMG=http://img38.imageshack.us/img38/519/fmic3210033.th.jpg] [IMG=http://img38.imageshack.us/img38/9519/fmic32100345.th.jpg] [IMG=http://img38.imageshack.us/img38/226/fmic3210032.th.jpg]
As should be obvious to everyone, I'll have to put endcaps on each of these with concentrically-located nipples mounted for my gas lines. That shouldn't be difficult to do. So I'll either be brazing or heliarc welding them, depending on which metal the endcaps are.
Did I make it clear enough for you to understand before?
I really want to say Thank You, sdupmer. I actually felt a sense of, they may begin to take me seriously after all. And that felt good. So Thank You!
About the camera issue. When I first started this project, I didn't own a digital camera. I brought one just for this project. The first one I brought about two months ago, died. It simply won't power up no matter what I do. The lens locked in the open position, and gave up the ghost. So I brought another digital camera. Ironically, I got it earlier the same day I got my compressors. And given my experience with the last one, I wasn't sure what to expect with this one. But as can clearly be seen, for the time being anyway, it's working. So I hope I will be able to maintain my earlier promise to have pictures of every stage of this project. And I'll try not to be too excessive, which can be a problem for me (As some may have noticed!).
I guess you can all thank naja002 for kicking me in the pants to get a camera. So I guess I should thank him too!
So I'll need to get two caps for the York compressors, and four for the Rechis. Good to know they're not expensive. So another question I have is whether anyone has ever seen any other major device combined with an oil-trap?
I read in one of the other threads (in this forum) that some one thought the image of the combination accumulator/sub-cooler (I've posted again) would have worked for oil trapping as well. It was just a suggestion. So I'm wondering if such a thing really exists? I'm the kind of guy who likes things that can perform more than one function.
I'm going to need something to provide for the equalization of oil pressure between my compressors for the tandem arrangement to work properly. The Yorks already have quite substantial accumulators mounted on them. The Rechi's accumulators are much smaller. What do these images tell any of you about how I'd have to equalize the oil pressure between the York compressors? I've really not wanted to drill any holes in the compressors, (as has been suggested many times) without knowing what's on the other side. At least with the diagram now I can tell what's where.
[IMG=http://img25.imageshack.us/img25/695/compressordiagram.th.jpg] [IMG=http://img25.imageshack.us/img25/4508/compressoraccumilatorfu.th.jpg] [IMG=http://img25.imageshack.us/img25/9958/compressoraccumilatorbo.th.jpg] [IMG=http://img9.imageshack.us/img9/1166/compressorrechiaccumula.th.jpg]
One thing to keep in mind about all of this. I will need oil traps after each of the three tandem compressor groups. The separate subcooling loop won't be a problem, since it is isolated from the main refrigeration loop. But the main loop presents a bigger problem to deal with. That's because the larger York compressors will be in the same loop as the smaller Rechi compressors. Now it seems intuitive that I should be able to isolate the Yorks from the Rechis by simply having each tandem group return oil from their own trap, back to the same group. If that's correct, please let me know. But, I still need to equalize the pressure in each of the separate tandem groups.
Good thing I got the camera, huh?
Thanks guys!
Shingoshi
So, I 'm a bit distracted!!
All of this criticism about me not taking pictures has led me back into my old first love. First I got one digital camera which failed and forced me to get another one. Now that I've gotten the second camera, I wanted something that could use to record video. So I tried bidding online for a Canon L1, thinking that I would have work done on it as required. I lost that bid and moved onto another. So I tried bidding on a Canon XL1 (which was absurdly foolish) and lost that too!
Ultimately in frustration, I decided to build my own video system. Having years of experience with interchangeable lenses, I didn't want a video system which didn't provide that functionality. So I thought, "what could give me what I want on the cheap without losing an quality in the process. The answer came as a CCTV camera which I purchased. It's a Samsung SSC-131A Digital CCTV camera. My next focus was on my lenses. For that, I chose to use the Leica M39 Thread Mount system. My second line of attack is the old Pentax M42 Universal lenses of old.
I'm telling you all of this for two reasons. One, to let you know why I haven't posted anything in a while. And two, to maybe give some of you the chance to consider alternative approaches to common problems. My goal here was to have a video system to document the progress of my build. Still pictures simply won't cut it here. I need to provide the means for some to actually see how things are put together in a way that provides greater clarity of the subject matter. So I'm posting pictures of what I've accomplished so far in my distraction, and probably won't post anything else here about the camera again. I just hope some of you find this fascinating. It has certainly brought a big smile to my face.
This is basic camera as it was acquired, and the Leica M39::C-mount adapter:
[IMG=http://img21.imageshack.us/img21/7971/samsungscc131adsc00054.th.jpg] [IMG=http://img195.imageshack.us/img195/1066/leitzoutdsc00070.th.jpg]
The camera with it's lens removed, and the new Leica M39 adapter waiting to be attached:
[IMG=http://img195.imageshack.us/img195/2315/leitzoutdsc00071.th.jpg]
The Leica M39 adapter now attached:
[IMG=http://img195.imageshack.us/img195/3656/leitzoutdsc00074.th.jpg]
The back of the camera (Note the BNC::RJ45 connector):
[IMG=http://img21.imageshack.us/img21/5761/samsungscc131adsc00056.th.jpg] [IMG=http://img43.imageshack.us/img43/893/scc131acamerabackdsc001.th.jpg] [IMG=http://img43.imageshack.us/img43/1395/scc131acamerabackdsc001r.th.jpg]
I also have a M42::C-mount adapter. It's shown here with the camera and the Lentar 28mm f/2.8 lens I just got today from Ebay for $26:
[IMG=http://img23.imageshack.us/img23/3914/tmountm39adapterlentard.th.jpg] [IMG=http://img23.imageshack.us/img23/5871/tmountm39adapterlentarde.th.jpg] [IMG=http://img23.imageshack.us/img23/4807/tmountm39adapterlentardc.th.jpg]
The lens I got today almost looks new, with the exception of some wear on the lens mount (like yours) which is never seen while in use. I'm going to post pictures of it for you to see. It's absolutely pretty!
http://img268.imageshack.us/img268/3...terlentard.jpg http://img195.imageshack.us/img195/4...eddsc00122.jpg http://img195.imageshack.us/img195/3...eddsc00123.jpg
I found this link when checking to see what quality I should expect from this lens. There may have been other links for others. But this page really convinced me this lens would be a good bet for my system. So as I have already done on Hin's Tech Corner, I really want to thank him for the affirmation to get this lens! Just look at his pictures to see why!
That's the end of my being off-topic!
At some point though, I will also install an observation camera inside the case as well. Something small with a very wide coverage angle.
Xavian-Anderson Macpherson
ShingoshiDao
[IMG=http://img24.imageshack.us/img24/4359/lentar28mmf28dsc00124.th.jpg]
