Uniform bus, ht and nb. I hope nb will go +4500 with cold
http://img40.imageshack.us/img40/7614/screenshot467.jpg
TRUE + 120mm fan
Phenom II X4 955
Gigabyte MA790FXT-UD5P
Crucial Ballistix 1800MHz CL8
Seasonic 430W
Quick 3DMark CPU Test run
http://www.pohrani.com/t/1T/ug/12fRJ1u9/3d.jpg
max validation by now = http://valid.canardpc.com/show_oc.php?id=799087
Thanks for those clarifications on the temps guys. Looks like my 720be just ran cold, or the temp sensor was borked on that one, I guess. My temps seem to be in line with what has been posted by Titan. Around ambient +6-8 degrees at idle and similar to your numbers at load. Thanks again.
BTW would +6-8 degrees at idle over ambient good enuf?
got a few here.
c2 on air 3hours of prime
http://img197.imageshack.us/img197/8030/40stable.png
700e benching at 4.15 had it to 4.25 but i lost my cpu-z :(http://hwbot.org/result.do?resultId=910870
and my 965 c3 validated :D http://valid.canardpc.com/show_oc.php?id=809139 on air
whau, very nice chip!
Wow nice clocks and an even better background...
Can u share some of the settings with us?
:-) Phenom II C3 vs blond babe :-)
TRUE Black + 2x120mm Antec fans, air temp ~15°
http://valid.canardpc.com/cache/banner/797753.png
ROFL, that's AMD section... Sry :rofl:
ermmmm that's my old c2 not the c3. and yeah she is hot but i had to reformat and cant find that babe that likes to look at my cpu-z screens :(
just did that on 1.425 VID and 1.475vcore that ram timmings sucked big time tho it just wasn't having it even with stock nb speeds.
the c3 i linked is sitting pretty at 4.05 and 830mhz on the ram 7-6-6-24-1t right now with high nb clocks aswell :) not much of an improvement but for benching its immense
I might sound stupid here but whats the difference between VID and Vcore? ANd whats the cooler u r using?
http://tinyurl.com/ydcvgnk and im using a cooler master v8 with an extra 38mm fan on the side. its always given me low enough temps and i have the bong cooler on standby :cool:
Thanks, I had a look and from what little I understood its the additional V u run to get it more stable under load. Now how do I do that on my MSI?
And by the way U got some pics of that cooler setup??
hmmm yeah http://www.overclock.net/water-cooli...ng-56k-go.html bong cooler and http://www.overclock.net/7572154-post8769.html the v8
pretty sure you can set the core vid in the bios on that board but use amdod if you cant find it
Thanks a lot El Gappo the destroyer....
why there is no 720BE?
is the 720BE easily hit 3.8GHz?
I tried to get it stable at 3.5GHz even at 1.485V, using Asus M4A785D-M PRO and Team Elite DDR2-800 RAM...
Some results:
Some benches that I did today
3dmark vantage:
http://img687.imageshack.us/img687/5...tagenvidia.jpg
3dmark 06
http://img39.imageshack.us/img39/2874/06nvidia.jpg
mav: Lower clock, better CPU score ,-) (set higher NB clock)
only for comparsion quickrun:http://img689.imageshack.us/img689/8...0mhz2639mh.jpg
Flanker compare XP to Xp not vista or win7 when comparing cpu score ;)
ouch, right,i forgot it :)
