Nice, but still we need more right?
What about the score I've got is it where it should be?
How many machines do you have crunching?
It's hard to gauge your productivity after just a day or two. You'll usually begin to see your real daily average by the third day.
We could always use more members.:) The real key is getting people to crunch on a daily basis. Less than 30% of our team generates points on a daily basis. If 50% of the team crunched daily, our numbers would skyrocket. And we don't necessarily need individual team members to produce big numbers every day (though big point producers are always welcome:D). If 500 members generated 2,000 WCG points each on a daily basis, that's a million points.
Just to put it into perspective, a single quad-core will generate between 15,000 and 20,000 points/day, depending on the overclock. A quad core with eight threads (i7-920, i7-930), will generate between 25,000 and 30,000. An overclocked hexa-core (i7-980X) will get 40,000-50,000.
well i've just joined but it will take a couple of days for me to get started.
this weekend i'll have some time to set this all up.
a quick question does memory help out a lot?right now im only running 4gigs
in my i7-920 rig,going to be getting triple channel kit soon.
Questions.
When I first signed up for WCG I also signed up to BOINCstats.
Today I checked BOINCstats and it shows nothing even though WCG stats are updating. Then I tried to join XtremeSystems in BOINCstats and get the error "no response from project".
So I go into BOINC manager and tell it to sync with BOINCStats BAM. Next thing I know BOINC manager has stopped? Try and update and the program crashes :(
What did I do? Why are stats not showing up on BAM? How do I get my stats in BAM, if I do a search for my name I find some else in Sweden has the same name? Why can't I join XtremeSystems in BOINCstats? What is the value of using BAM ?
Sorry for all the question but inquiring minds need to know.
John
great to hear.i'll install the software soon and start crunching so can get a handle
on how this works and be ready to crunch the first week of may at full power
There are numerous BOINC stats sites. But they don't all show updated stats at the same time. This morning I had to go to the Free-DC site to get numbers for the newer members.
This is your page at Free-DC:
http://stats.free-dc.org/stats.php?p...cg&name=681494
Free-DC is not always the site to show updated numbers first.
I'm not sure how to fix the BOINCStats BAM. I've never seen that problem before.
I've never tried to sync the BOINC Manager with BAM, so I don't know. Perhaps someone else can chime in.
One thing you could try. On the BOINC Manager, go to Advanced, then Preferences. Hit the button in the upper right that says "Clear". The manager will default back to the web-based preferences you chose at the WCG site. If you want to run at 100% load, just make that's indicated in the Device Profile section.
Obviously I don't have a clue :(
Before I was able to Clear BOINC Manager shutdown by itself down this time?
http://i168.photobucket.com/albums/u...01-30-53PM.jpg
I'm going to BOINC stats to shut it down until I figure out what I'm doing.
Thanks for the help.
John
I think you can just disconnect from BAM from inside BOINC manager. I think all it really does is help you control what the machine is crunching remotely. Seeing as we are the "set it up and let it run" types, I have never found the need for it.
Apologies in advance if I'm posting in the wrong thread...... followed mm's announcement here. I'm in with 6 to 12 cores for the May Super Computer push, depending on the weather, distributed heating I like, cooling it not so much.
Hey Rick I see you still have your head :D
Well guys been a while since I have been on the forums. I have joined and installed WCG software, now will add BOINC Manager. Currently running it on wifes dual core X2 550 at 3.5 w 4gb DDR2. Plan to install to my PH II 955 running at 3.7 w 8gb DDR3
I just built a system out of spare parts last night and added it to the cause
(AMD Athlon 64 3400+ / 2gb ddr) nothing extraordinary but i figured it could help a bit :shrug:
Excuse me guys, just had to do a little thread cleaning and remove some garbage..
Thanks for this post. I've read that anything up to 90C is fine for i7, but wanted to check - and behold, the answer :D I've just OCed that i7 920 that was sitting turned off before I joined WCG couple of days ago. I've just blindly set the BCLK from 133 to 166 and it all works.. Prime after ~1h has it around 89-90C, no errors.. hopefully all fine. WCG keeps it at low 78-84C as much as I caught so far.. Btw, measuring with RealTemp.exe, v3.4, hope it reads these CPUs well enough..
LOL! That's why I went to "top list" of teams, and joined one listed there.. ;) I thought "they're here, can't be wrong team" :D And it isn't ;)
Just wanted to say that! I've been watching videos, browsing, doing some office-level work.. nothing hard.. But it never flinched. If I didn't look at Task manager I wouldn't even know it's running. Oh, and not having to turn on any heating last few days ;D But really, app is great in that respect, I can actually have it on and running 100% all the time, and not think "oh, got to turn it off so I can run this FullHD video or it will stutter".. no way! Real smooth! That's on my "home" E4400 CPU, nothing fancy btw..
I do have one question, at whoever knows the answer. Except by BSOD-ing, is there any way to know if perhaps CPU is giving out errors? I'm not concerned with my E4400, it's been OCed few years, and never had troubles with it, as long as I stay at/under 3.2GHz. But I've just OCed that i7 920 to 3.33, it's got stock cooler, running in those mid-low 80s when running WCG, but I've had Prime running only ~1h at once, though had total of around 4 hours of 100% CPU so far under either Prime or WCG today, so far didn't notice anything. But since it's running WCG now, not Prime, I'd like to know if there are any ways to spot errors that do happen but don't crash application or OS. Prime is great there, throwing out errors and so on (at least it did years ago when I last used it).. but don't know about BOINC x64 client.. Any help is appreciated :)
Oh, and I didn't want to "waste" time on running Prime for longer time, I want to process those WCG packets :)
EDIT: Darn this i7 is precessing packets 5.5x faster than my C2D.. and that's before I've OCed it.. Gonna have to buy me one :P
Go out and get yourself a better HSF than stock and you will be able to get that bad boy up to 4.0 GHz in no time, rock solid stable too I bet.Quote:
You can check for non-BSOD errors by going to the WCG website, login to your account and then change the Result Status filter.
http://www.worldcommunitygrid.org/ms...Time&pageNum=1
I'm having some errors coming out like this(about 15 all the same):
Result Name: ng727_ 00006_ 9--
<core_client_version>6.10.43</core_client_version>
<![CDATA[
<message>
Incorrect function. (0x1) - exit code 1 (0x1)
</message>
<stderr_txt>
ERROR:: Exit at: .\dock_structure.cc line:401
</stderr_txt>
This means?
i got 4 of those errors too,
but noticed the cpu time on them was too short, still some credit was still given
Which version of BOINC are you guys using? And do the errors appears on a particular project or on all of the projects?
Errors can be caused by a number of things - unstable overclock, bad work units, Beta BOINC client with bugs, etc. The Human Proteome project has been known to cause errors.
