my mountainmods ascension crystal ship
http://www.xtremesystems.org/forums/...postcount=1648
i hate the way the HK3 looks.
im waiting on the evga 270-gt-w555 to go with my xeons, 12gb ram and 4 gtx295s which will all be on water. THEN it will make sense for all that cooling.
Here is my latest. Going to redo the loop though and sleeving, just waiting for some more parts.
http://img38.imageshack.us/img38/155...irbuild.th.jpg
My gaming Rig (Supernova)
Project log link in my sig.
http://i120.photobucket.com/albums/o...g/EOS352-1.jpg
http://i120.photobucket.com/albums/o...log/EOS349.jpg
http://i120.photobucket.com/albums/o...log/EOS338.jpg
http://i120.photobucket.com/albums/o...log/EOS322.jpg
My mini ITX setup.
Specs:
Zotac 630i
E2180 3ghz
2gb ram
500gb Seagate
350w HEC mini ATX psu
Case is a modded Shuttle KPC
Cooling is a modded CM Aquagate loop
80mm Black ice Rad
mcw30
CM Aquagate CPU Block w/integrated Pump
Tygon 7/16 Tubes
MCRes
http://i120.photobucket.com/albums/o...tleExotic1.jpg
http://i120.photobucket.com/albums/o...tleExotic8.jpg
http://i120.photobucket.com/albums/o...leExotic10.jpg
http://i120.photobucket.com/albums/o...tleExotic4.jpg
Superb work Nashaz...! :clap:
Well here it is:
my smexy Apogee XT :D
http://i600.photobucket.com/albums/t...s/IMG_2205.jpg
FrozenQ's Inverse T-Virus Res. Pure secks.
http://i600.photobucket.com/albums/t...s/IMG_2209.jpg
http://i600.photobucket.com/albums/t...s/IMG_2210.jpg
Inside with lights on
http://i600.photobucket.com/albums/t...s/IMG_2201.jpg
Inside with lights off
http://i600.photobucket.com/albums/t...s/IMG_2197.jpg
These 2 are really dark, but I love how sleek the tubing looks =)
http://i600.photobucket.com/albums/t...s/IMG_2190.jpg
I really like how the fading is on the reservoir in this picture
http://i600.photobucket.com/albums/t...s/IMG_2191.jpg
2 awesome pictures to finish off this post with :D :D :D
http://i600.photobucket.com/albums/t...s/IMG_2193.jpg
http://i600.photobucket.com/albums/t...s/IMG_2188.jpg
gravedigging....
another small-packed water....
http://img14.imageshack.us/img14/7691/sdc15426.jpg http://img62.imageshack.us/img62/3589/sdc15433p.jpg
i hate the antec 300, why cant they make it with a side pannel window,and why a bottom mounted psu,makes no sense,and poor cable management
the haff 932 looks pretty nice/have the option of top mounted or bottom mounted psu/has fan holes for top mounted or bottom mounted rads/has a large amount of 5.25 drive bays /which i like to put hard drives in/can cut out the 3.5 drive bays for more room/the bad thing is only the amd eddition one has a nice window/the regular one has a crappy window
:p:
http://i70.photobucket.com/albums/i8...n/IMG_0650.jpg
still a lot of work im planning on doing to it but it should be done very soon :up:
What's wrong with a bottom mounted PSU? There are a lot of cases who also have bottom mounted PSU's (800d, and lian li has some too).
And with some innovativity, any case can get some degree of cable management.
http://img29.imageshack.us/img29/9683/cimg16852.jpg
http://img638.imageshack.us/img638/1164/cimg173221.jpg
Took this before I replaced my 8800's with 5870's
here's mine in an NZXT Tempest
2 x triple rads, one in the top, one in the front
3 x VGA FC
http://www.xtremesystems.org/forums/...d.php?t=242253
Thanks, No rads - 100% TEC w/ Heat Sinks & Fans (All Internal System)...
Sure.. Made a hole to the back wall that allows the PSU to slid in/out and reinforced it with some flatbar. Not pretty but it works fine.
http://i608.photobucket.com/albums/t...i/STA73728.jpg
On the all the Silverstone links all I get is this --
Why?Quote:
Invalid Post specified. If you followed a valid link, please notify the administrator
