Yes, and also Non NF200 board.
Thx to Kevin for this one...
http://img38.imageshack.us/img38/4214/0610406.png
some tweaks done raju..? thats a very good score for 5.3Ghz :D
edit: I can see it now, dual channel is faster?
Why only PCie 8X?
Great CPU
not sure if dual channel adds more in '06 but its defintely faster in '03
but i dont think this trick is to do with dual channel RAM
Quick Vantage CPU test;
http://img156.imageshack.us/img156/4841/vantage5230.jpg
your cascade holds a solid -108 at vantage test..? thats sick...
It tips to around -106 in this one. Ales did a great job on this unit, it's very powerful..
How much cooler at idle does the D0 run compared to the C0/C1 when NOT OCing? I ask because I don't OC (yet), I have a Thermalright Ultima90 w/120mm Noctua fan and the room the computer is in has no A/C during the summer. The room easily hits 32c during the summer.
raju,
Your 3DM06 run is an amazing achievement, thanks for sharing and hope to see even bigger numbers in the future. :)
raju
please make sure you post GPUz tab when you post CPU scores in vantage or '06 otherwise the number means little on its own
any more 920 testing :D those are really exciting numbers on such a cheap CPU :yepp::up:
It's a GTX 280 @ clocks of 704/1215 and that's about it for those 2 runs above.
