http://img519.imageshack.us/img519/2426/aod42pi4.png
I hope this is real........seems a little out of touch with all the other people ocing. I mean I like these results but this seems to good to be true and with only .10 more volts than stock?? thats 1200mhz on just an extra .10v
I don't think those voltages are correct in AOD. If I had to guess they are above 1.55 to get to 4.2
dang...you beat me..although I haven't had a lot of time to paly with my toys because of my job. Peaople say times are tuff, but our clients are spending money...I only have one screen shot on my website, but not enough info for the chart till I get home. I guess i need some ln2 to beat you lol...:p:
great job tho man..:up::up:
I wish I had my PIX up, I could remote home and get some files pulled. I might see if my wife can send them to me.. hear is all i have for now.
http://3800z24.info/Phenom/Deneb/Pi_1M_4ghz_small.JPG
In post 151 he used a similar screenie of AOD 1.35v 3.5ghz and said not bad at stock voltage...so now these arent showing the right voltages??
Well I dont know.......just dont want to be blinded ..........maybe hes using ice water or something? Well I hope its real......wouldnt mind hitting 4ghz@1.45v
can it be so hard to achieve?
I'm doing the same with an intel chip prime stable......
Why would it be hard to believe for amd, sheesh my x2 3800 @ 90nm did up to 3.0 on .10 over stock.
Alot of overclockers just immediately go for the gusto and increase cpu volts expecting an uber high OC.
The ones that actually acchieve high clocks take they're time, tweak and give as little volts as possible......
If you look at his temps they are 33C which is just a tad below room temps, water cooling plus maybe an open window, honda whats load temps like? I'm guessing max 50C under a sustained load like prime for a few hours?
For reference a mach 2 pulled 1800mhz at boston event on .10 over stock........these chips do not scale well with voltage, they however scale higher at the same voltage when kept cooler.......when frozen below phase temps then you can throw volts at em.......
Its simple more volts = higher temps = less OC.........lower volts = lower temps = higher OC.......
yes Ive seen all the info online......thanks, I see everything you see........but Im the type to have some doubts sometimes......I just wont flow with the grain because everybody is on a high and wants to believe everything they see. I really dont want to insult anyone but Im going to speak my mind if I feel something might look a little strange to me Im going to question it. But I also realize maybe hes running chilled water or something thats why I mentioned it:hm:
Like I said I hope these are the kinds of results that will be common......theres alot of ocers that been here for a long time that should be able to do the same. Anyway I wont mess up this thread any further........good luck with the overclocking guys.
Shouldn't be too hard. My 940 seems to be doing 3.8ghz on stock voltage with a bios that doesn't even completely support it. I was able to install vista at 3.6ghz cpu and 2.4ghz nb with thos being the only settings I changed. No screens right now, I'll be working on that tomorrow while I do laundry before I go back to school along with getting everything installed on it. I didn't even take the time to put a wireless card in system yet so I have internet at the house. But the only thing that matters is that the vapo works, other than I put a connector on wrong because my lcd temp thing on the front doesn't show anything useful.
wPrime 32M @ 3800MHz: 9.857s
http://www.pcrpg.org/pics/misc/wprime3800sm.png
Max SS so far:
http://www.pcrpg.org/pics/misc/cpuz3900.png
Ok little progress but still tweaking.
Stable prime:
http://www.aijaa.com/img/t/00099/3347065.t.jpg
http://www.aijaa.com/img/t/00318/3347072.t.jpg
Win XP and water cooling
Other parts in sig. :)
3.9 stable, nice!
Is that second picture showing 4.1 stable or what? The current speed in AOD is showing 4.1 but cpu-z has it at 3.9 still while running prime.
@Particle - I put you in the table but I'm missing some information from you. Stepping, Mobo, and Memory Config(Just guessed 2x1gb)
New list uploaded with 10 minutes.
Edit: List updated and its really sad that I had to spend 15 minutes trying to find the control panel on asetek's site for my vapochill. Search for downloads and it comes up with nothing.
Information:
CACVC AC 0850BPMW
http://www.pcrpg.org/pics/misc/p2-940-cut-sm.jpg
Foxconn A79A-S 790FX+SB750
4GB PQI DDR2-800 (2x2GB)
Xigmatek HDT-S1283 120mm (Air)
Windows Server 2008 x64
So far everyone has had different motherboards, I wonder how long that'll continue. Thanks for the rest of the information Particle.
Volts are at 1.625... is is done with XP XP3 32 bit
http://img530.imageshack.us/img530/9...nomii48bw9.png
http://img514.imageshack.us/img514/8...nchmarkoy8.png
1.625 for the 4.8 or the 4.2?
Is that 4.8 on water?
Because last I've been seeing cascade and such seem to be getting not much higher than that 5-5.3
holy :banana::banana::banana::banana: :D
update your sig pls ;)
Anyone else having trouble with multipliers higher than 19 regardless of voltage? Perhaps I should bump HTT a little...
I need to update my bios to figure anything out. I'm installing drivers/utilities as I'm typing this. Right now its at 3.7 cpu and 2.4 nb.
Man... seeing you hit that on water makes me really want to get 5ghz with the vapo. Do you want me to switch your entry to that with the new os or just make a new one since its a different os?
Old guy is that 3.7 (3.8? from sig) with 2.4 nb with air or on your vapochill?
Anyone know if the heatspreader is soldered?
Anyone done some power consumption measurements when heavily OC'ed?
4.8G on water? Amazing. =)
Wonder what will happen in coming months once the process matures...
http://largon.wippiespace.com/smilies/1012.gif
I got 3.7GHz out of the box with 1.45v on air.
http://img396.imageshack.us/my.php?image=940oc2kx7.jpg
I am overclocking using AOD at this time. I am going to find my max with it. My first crack @ 06 with HD 4870 1Gb Crossfire is 20235.
http://service.futuremark.com/compare?3dm06=9560945
I'm using the old 8.10 driver because it is the least problematic.
More results in a bit.
PH1 is soldered, I dont think they would change this on PH2
Oc'd from bios...On air unoptimized.
http://img530.imageshack.us/img530/3...shot037zp8.jpg
Its on the vapo, didn't even bother touching it with air. 3.7 with just the multi didn't like prime, I'm going to try from the 18x multi and go up using htt. I haven't touched volts yet, I want to see exactly how far it goes on stock first.
