Originally Posted by
dejanh
I just got off the phone with Asus support where I laid out all of the problems seen so far with this board...the list follows...
1. Disappearing memory channels/memory detected incorrectly (e.g., only 2GB out of 6GB get detected at boot). Depending on settings, this can be triggered at will and is not normal. BIOS used does not affect or correct this.
2. Instability at 200MHz BCLK and/or 20x multiplier (but not above or below). Possibly there are more combinations that are unstable with 20x multiplier.
3. IOH voltage is stuck (i.e., cannot be changed and/or there is a huge discrepancy between the set voltage and actual voltage...I'm talking 0.08V or higher). In one example I set the IOH voltage to 1.32V and the actual voltage read only 1.24V, same as when the voltage was just set to 1.24V. I don't think 0.09V is considered acceptable discrepancy. Furthermore, no matter how high I go with the settings (I tried 1.5V) I only got 1.28V max on the board using a DMM. That's a whopping 0.22V difference!
4. Random (cold-boot) no power up after shutdown. Appears to happen for no reason, PSU was ruled out, DRAM was ruled out, BIOS was ruled out, graphics were ruled out, even CPU was ruled out. Requires typically a CMOS reset, complete power cycle, or a wait time before trying to boot after initial failure.
5. Motherboard not rebooting correctly after a BIOS update and requiring CMOS reset to be hit every single time (this is not normal behavior).
6. SLI Configurations not working on all of the boards. I did not try this on my board.
7. ROG light not blinking when the computer is off as it is supposed to but instead staying steady. This appears to have something to do with the cold boot as they seem to happen in conjunction, but I am not 100% sure.
8. No ability to delete O.C. Profiles from BIOS without reflashing the BIOS.
Anyway, my board is going for an RMA as soon as Asus verifies advanced RMA stock for shipping to Canada. Hopefully, the new board will have no problems. If Asus forums are any guideline I am in for some good times, at least in terms of the memory issues. There have been a couple of individuals there that had this issue, RMAed the board, and the replacement worked flawlessly. I do hope!
