just recieved a ADA3200
CAAMC 0338XPMW
cant wait to get it under the prommy..
CAAMC 0338XPMW
0336TPAW Ran 260x10 1:1 24/7 on Mach II @ 1.64V
0333SPAW Ran 235x10 1:1 3D stable on air @1.62V.
Running FX-51 @ 230x10 1:1 24/7 stable on 1.52V.
Mine is a CAAMC 0342 and the max I can do 3dmark stable is 2655mhz...... was hoping to do 2700mhz but 2655mhz is the most she'll do even at 2v......cooling is by -20c water..... nevertheless its good enough to break 27K with my 9800pro:D
http://service.futuremark.com/compare?2k1=7308727
i just saw your 9700pro score luihed. 24000 is very impressive too. that makes you #1 in the class. seriously nice going
i just swopped to a 9700pro-aiw and cracked 22500 all air
core mem 474/338, vgpu mod
http://service.futuremark.com/compare?2k1=7322299
Thanks flytek...... Im gonna give her more this weekend and see if I can get close to 25k which is my goal....... my rig is not maxxed out but I dont think its got an extra thousand pts in there..... 478core on your 9700p is awesome.... especially on air:slobber: how much voltage are you running though it?
i'm not really sure. at max i was just twisting that little vr until it went fast enough to take #1 in the country. i'm sure it was substantially over 1.8v though.
Lol... I know what you mean man...... sometimes its hard to stop turning the vr............ anyways again thats awesome clocking 9700pro you have there so take good care of it...... :D
So you're running a PCI spec of 43? Great...Quote:
Originally posted by MickeyMouse
0335 "R" in third code line - 2600mhz at 1.7V rock stable on Chaintech NF3 mobo, 4th highest score on ORB. ;)
newegg OEM and with IHS removed prommy MACH II cooled..
was held back becasue this board wont run the 5:4 and I didnt want to push over 3.25v through the DDR as it was brand new still.. so 260 1:1 was all I was able to really push It to.
That's a PCI spec of 47 :eek:Quote:
Originally posted by bowman1964
well this chip likes speed i guess.
How in the world are your components keeping up??
With my newer A64 and K8NNXP I'm able to hit 233-234 fsb but crashes sporadically because my SATA drive is holding me back with the onboard controller. Also, no vdimm mod yet so the memory is 5:4.. 430/365 9800p - 22,000+ 3dmark01
Whoo wat FSB/MEM speeds are you running ?Quote:
Dammm those A64 rock :P
ok, i got my chip. still waiting on the motherboard and heatsink, but the stepping on the cpu is:
ADA3200AE5AP
CAAMC 0339WPMW
9446543130306
how does that look?
What is ought to be the best A64 stepping ? XPMW ?
0341 Brown chip cooled with Mach1
http://sites.rapidus.net/maxbleau/352%20cpumark.JPG
i think this pic will say,all i need to say...:D http://www.xtremesystems.org/forums/...&postid=310228
What kind of mem is running there :slobber:Quote:
all i can say is..it is some of the latest memory from OCZ i am testing now...
Just some "new" OCZ isn't enough ;)
More info :)
PC4500
yea its the replacement,i have 3 motherboards now i am testing.a gigabyte,chaintech,and a new shuttle.Quote:
B> is this the replacement mobo from newegg??
How is it over the other is the vcore/agp issues still there or are they now fixed??
you know one sec high gpu clocks next none and vcore over 1.96v black screen????
very nice BTW thats some nice ddr and I bet rock stable at 295mhz or close ;)
GJ
i was wonrking on the ovp protection last night and got it working on the shuttle.took it over 2.01v without shutdown.before it was like all the boards...1.92 to 1.96 and shutdown.
as far as stable at 295...not good enough for me yet.the chip cannt stand the high clocks yet. that was almost a 3 gig chip.i tried to get a 3gig post and havent been able to yet.
i am testing and then i am getting rid all all but one setup.
Still nice :DQuote:
I hope there will be an abit motherboard soon with nforce 3 and 3.2 vdimm... BURN BABBY BURN!! (6)
Bowman,
Please let me know when you get the ovp figured out for the Chaintech.;)
Mickey,
I need the Chaintech bios that allows memory settings. Do you still have it or a link to it?
Anyone have a link to clockgen for the Chaintech? Not sure which one to use? Thanks :D
Just now setting mine up in Mach2...I've had it for months...first chance I've had to install it...using it in Mach2 review/guide along with regular AMD install.
In a few days I will receive my new A64 3000+ 512KB with code CAAMC 0349 RMPW.
I hope this will be a good one, because I haven't seen this type of code in the forum.
I have now about a week a athlon64 3000+
I have it whit stock cooling oced to 2,5Ghz
It's stable whit prime95
But I hav 1 problem ant that is my radeon 9600pro it hate high agp speed :( Wit a agp bus@ 78mhz than can't he hold it any more :(
[img=600,400]http://www.actelecom.nl/gallery/albums/album01/pifast.jpg[/img]
Now comes my question.
Can I flash a Sk8v bios in my K8V?
An can I use mp's higher than 10 whit my 3000+?
that would be great if that can :banana:
Sorry for my bad english
