Excellent! ..results
http://images.uncyc.org/commons/thum...px-MrBurns.jpg
Thanx Chri$ch,
F3d in test info
We all need to get info from the sources who have first hand info such as yourself, and then help to spread the correct info so that we can null the BS. We also need to send e-mails to these places to retract false info.
Not quite. Mnay mopre are coming out that are Multithreaded. Most flight sims benefit greatly from from these CPU's. There is alot that is done by the CPU in flight sims. This winter I bet Multithreaded titles are gonna become the norm, and another bet is within a year they will be haviliy multithreaded. We're into 64bit OS's being the norm now, and all current CPU's have already jheaded that way. Everything is going Multithreaded. It is as sure as Multicore CPU's are today. Those that can't code Multithreaded will find themselves obsolete and without a job. I talked to somebody about it today that does this for a living. He "grew up" with single threaded, and is having a hell of a time schooling up, and relearing how to do it efficiently.
Not just fairly well...exceptionally well. Once we figure out how to dial in all these new BIOS settings, OC's will get higher. I'd be willing to bet 4.5 is gonna be easy on water. 4Ghz on the 965 Extreme's is a piece of cake. I've already seen the BIOS shots and they did 4 on stock volts and stock air. That was on a RIIE with 3 way SLI. It rocked!
Tom's posts alot of things, but that doesn't make them correct, and in this case it was very wrong. See Dr. Who's replies. Nobody knows this CPU better than the people who worked on it. Some like to think they do though.
Wrong! Absolutely false. See DrWho?'s re: 2 quotes below.
:rolleyes: For the people that actually have them and have used them, they've said the exact opposite, and their OC's drive it home. There is nothing at all wrong with that board. in fact, it was generous of Intel to work so hard to make it a great OC'er. They didn;t have to include *any* Oc'ing options, but they did just for us. There are lots of people who will like that board. Telling other's not to buy does a diservice to Intel, and is rude. :(
Thankyou! I'm so glad you are here. Your info is highly valued and I know it's been alot of work for you to help keep good info out there. It's helped me a great deal,a nd is much appreciated! :yepp:
That should take care of the naysayers.
Yes. Asus, Gigabyte, Foxconn, EVGA and others.
Hopefully he'll update his website with correct info and read the directionbs next time. :D
From what I understand the 17th is official. At least I hope that info is correct. There are some places selling CPU's and stuff, but you have to hunt for them. I won't post those places here out of respect for Intel, but they are around.
http://img.3d-nexus.de/main.php?g2_v...serialNumber=1
I'm hoping to get my mainboard & ram tomorow. :)
Wow...I'm having a tough time deciding between the P6T Deluxe and the GA-X58-UD5
Both have yielded great results.
Is it true the P6T Deluxe doesn't do tri-SLI while the Giga does?
I just got my i7 965 Extreme today. Going to order Rampage Too Extreme tomorrow, and will be looking hard at memory next. Might have it running sometime in the next 2 weeks or so...hopefully. :)
Is 3.8Ghz possible with air cooling ( Noctua NH-U12P ) ?
Hi Chri$ch can you tell what batch is your 920?
3836a381 ;)
I got today GB EX58-UD5 also and i7 920 3836a772.
So I was curious is your also Costa Rica. :)
Thanks for sharing!
Rampage 2 965 @ 4227 on air. Still teaking and awaiting LGA1366 waterblock.
:confused: Huh? 4628.5 watt TDP? :eek:
What's up with Core Temp? That can't be right.
hello,
I see here very good results also with 3x1gb and 3x2gb Trible Kits.
hase someone informations about performance, 3x1gb to 3x2gb trible kit's ?
it is nearly the same?
and the Dimm-Slots it is still the same problem as it the board had Asus rampage extreme (A1 and B1) ?
Got my cpu to 3.2ghz with 1.19v will be going higher once my TRUE arrives saturday, or monday.
What is this throttle i am hearing about, can someone please explain it to me, thanks.
i went to 4.0 on stock cooler for a few minutes, i was idling at like 45-50C, and turbo mode still kicked in
i need a get myself a better cooler too
Guys how does it happen that the faster clocked 4.2GHz does a tun in 10.4 sec and the slower clocked 3992Hz in 9.8??
Memory ???
My turbo mode is on, so it kicked up to around 4.2 when i did the run, i have DDR3-1600 if that makes a difference
edit: that seems kinda weird. I think its my BCLK, mine is 200 while his is only 135
