LinX 0.5.4 with home-made HT support
Thank you all for your patience, here it is: LinX 0.5.4
Changes in this version:
- HyperThreading support added. This is done not in a best way probably, as two instances of Linpack are launched at the same time (their performance is then summed up). This was tested on a P4 and an Atom and worked ok in both cases
- Thread control added. You can now set the number of threads Linpack will create and thus control the number of physical cores that will be stressed. This setting is located in the Settings window (who'd have thought? :D )
- Settings window with all existing and a couple of new settings added. No need to edit the ini-file manually now
- Main menu redesigned
- Lots of minor bugs found and fixed (and who knows how much new are added? :rolleyes: )
- Performance optimized a little bit more
- Graphs have now customizable top and bottom limits
- And changed the icon a bit :cool:
Your comments are welcome as usual. I'm eager to hear how it performs on Nehalems now. :)
P.S. Screenshots and updated first post tomorrow, no time right now.
