Don't worry, we are too :up:
Check this slide giorgio, it gives you the info on Taiwan power - 3-pin Type B
http://flytek.effectivehosting.co.za...egulations.jpg
adapter is only a part of the questions, All the European guys are in 220V, and U.S.A and america in general use 110V... Taipei is 125V....
The problems isn't about the power plugs but the 125 -> 220V power :D
found solution, bought 2 of those:
http://www.fratellidelpiano.com/images/img/45FV.gif
is not just an adapter but a power converter, and is good for 50 watt, wich is enough for solder iron and hot glue gun :)
I'm hoping to update my status from media to media/overclocker :)
Today i just talking with GB person, they said it's 100% confirmed we will use HD4870 (reference card) in CF mode. They will release the new rule today.
Ohh so 2 * 4870s now??
Those converters can be bought from most electronic shops in Taiwan FYI
GB already changing the VGA spec. on GOOC site. But the funny thing, picture shown still HD4850 and the detail info is HD4870 with GDDR3 memory. :D
info on gigabyte website said GDDR3
But box said GDDR5
http://www.gigabyte.fr/FileList/Imag...512h-b_big.jpg
maaaaaaaaaaaaaan i hate the fact we are going to use quads
it would have been so much better if they used E8600 CPUs but i guess that's what they've decided :(
lol
hey hicookie
can you confirm if they will be GDDR3 or GDDR5 cards
reference or non-reference design
btw can you beat someone up who decided to pick QX9650 CPUs lol
we got no chance to break any records whatsoever with those things lol................why not go E8600....we could have been benching at 6GHz+ easy...would have been more exciting hehehehe
Is the freestyle event only for "Global" WR's, or are "Hardware" WR's counted and score points ?
