I agree, but it doesn't negate my point - most office apps aren't multithreaded.
I expected it to end up this way. We were talking about multithreading, not multitasking.
In this case flash player is just a plugin, not a separate app. And the browser that runs this flash is most likely singlethreaded.
Hello, earth here. "Do one thing, but do it well" - they all follow this philosophy, does it make them crap? None of them is shareware. None of them is adware.
Don't know how about you, but I don't have to install any codecs to use it, they come preinstalled.:rolleyes:
Anyway, it's the same case as with flash - application isn't multithreaded, just some extensions are.
You're talking about encoding - yes, it's (fortunately) usually multithreaded. I've been using LameMT too until I switched to loseless formats. But management (usually?) isn't. Playing - at least rarely.
How many of them are spawned by WinAPI? IE has a lot of them, if I got IE7 I'd check, maybe it is multithreaded (my IE6 isn't...no, I use FF), but I guess that the other ones aren't.
I didn't deny it.
So I guess that either you do some rendering, which most people don't or you're crunching, which is spending money on a hobby - surely not a waste, but not productive either.
The point is that this list is far from exhausting and MOST advanced tools aren't there.
It has 7zip. Where's FreeArc? Squeez? PeaZip? (all are multithreaded BTW)
It has Visual Studio. How about Eclipse, Code::Blocks, Borland C++, Delphi, Intel C++ compiler, tools for development in Ruby, Java, asm, Python, NSIS? Where are tools for HTML and flash development?
Matlab, Maple and Mathematica...Octave, MathCAD, LabVIEW?
Irfan View and XnView...Total Commander's lister, Universal Viewer?
MySQL...MSSQL, Oracle, DB2, PostgreSQL, SQLite?
Adobe Photoshop...GIMP? Corel?
Paint.NET...there's a dozen of valuable alternatives.
Apache..Nginx, WebLogic?
Where's version control? Virtualization? File managers? Backup programs? Encryption? Antiviruses, firewalls etc.? Wireshark and other network traffic analyzers?
And all types of software I mentioned before? Power users surf the web and listen to music too.
This list is not comprehensive at all it's just a useless bunch of software that 2(1?) people seem to like - you and it's author.
I'll leave this without comment.
