I not only turned off overclocking in CCC, but also stopped CCC from loading at start-up. Still I get the "fail" message for the card in slot 0. The same card by itself (no xfire) in slot zero, OCs fine. :confused:
I'm confused. Which driver is the best then, the official 8.7 release, or the 8.7beta? Also, does 8.7 fix the fan control?
tbh i had most sucess with 8.7 beta because theyr driver is newer than that in the 8.7 final, but someone says 8.6 hotfixed is better for them .. Try both of them, or all three of them
so whats everyone using for 4870 crossfire overclocking apart from CCC?
look around on the forums for Asus 4870 bios in the bios mods section the CCC limit on that is upped to 900 on core and 1100 on memory and 1 member showed a screenshot of theres at 885/1075.
That shows alot of promise to me specially with how big of an improvement overclocking brings. 1 review of it showed a 12% oc gave like almost even gain or something like that.
How can i overclock (+800 on core) with the fan at custom speed?
I tried 830mhz with automatic rpms and 3dmark '06 crashes with the high temps :rolleyes:
Is ATI Tool still a good utility for stress testing new GPUs?
for those that want to OC high and have an aggressive fan profile, just flash to the new Asus OC BIOS. it comes stock at 815/925 and lets Overdrive go up to 900/1100. the fanspeed profile will keep your GPU at or around 60° at all times.
http://www.xtremesystems.org/forums/...d.php?t=196551
so I flashed the asus top bios and got my cards going at 885/1075 (vmodded of course) and I was able to pull this beauty out of my hat. :D
http://service.futuremark.com/compare?3dm06=7643192
It's the highest O6 score on vista for 4870's that isnt a qx9650. Seeing as I don't have $800 (ebay) for one of those, I am extremely pleased with my result. (I even beat some qx9650's as well)
http://img148.imageshack.us/img148/6702/verifffk9.jpg
sorry for large size ;)
Very nice! This reminds me of when i volt-modded my 3870 to get the core up to 980 which resulted in just under 14k in 3dmark06.
this brings hope, I'm tellin u guys, if you want to push this puppy, gotta volt mod it, that's what the 55nm die is all about!
But I think i'm just gonna wait and return my Gx2 for the 4870x2 ^.^
Just flashed my cards with the ASUS bios but set stock clocks to 825/1000, running much cooler but still fairly quite :)
what are safe voltages for GPU?
what sort of voltages are ppl using to get to 875-900mhz?
update on my temps. i ran GRID in a very warm room today (82°F or 28°C) and my cards ran at 72°C with the fans going at 3200 RPM. still very quiet. i didn't check the percentage, but it was obviously lower than 45% because i know what that sounds like. i just want to reiterate how much i like this fan profile.
So here has been my project its been fun taken me a couple days to tear everything down and do my first watercool build. Was fun I am a bit of a perfectionist so... took me a while wanted to share my card results with you guys and some pics ;-) here they are
http://img337.imageshack.us/img337/3927/p1030414yr5.jpg
By turboz22l, shot with DMC-FX3 at 2008-07-28
http://img70.imageshack.us/img70/995/p1030430st9.jpg
http://img70.imageshack.us/img70/5281/p1030425hp3.jpg
http://img295.imageshack.us/img295/1442/p1030429oe5.jpg
http://img210.imageshack.us/img210/2658/p1030434ie7.jpg
http://img210.imageshack.us/img210/8991/p1030435wu4.jpg
This is before I watercooled it ignore VRM temps because I couldnt even run furmark with stock cooler so i had to settle for atitool
http://img401.imageshack.us/img401/2...rmtempsie8.jpg
By turboz22l at 2008-07-30
and now after the water cool running furmark stable no crashing VRM is still up there but it was flaoting between 124 and 126 and who knows if everest is right or if gpu-z is recording the right temps. comparing the gpu-z temps tho its incredible results running at 790 clock 1080 memory just from CCC now time to voltmod see how far I can take this card. all results are in 80F ambient temperature room!
http://img401.imageshack.us/img401/5...tercoolfq5.jpg
the second shot is the same as the first....
yeah I fudged up links I edited them I had last 2 shots the same as well sorry bout that fixed now.
looks great man, if you want any voltmod pics check the worklog in my sig ;) :up:
Thanks man ill take a look :-)
This is what i managed with volt modded 4870s in CF. Artifact free of course :). I'd like to see more, but they won't give it to me!
http://img401.imageshack.us/img401/7...9ab93c3wc0.jpg
WoW nice clock on the GPU there what kinda temps you running ? and what voltages you using?
