Steffen: The Nickel Acetal Combo will be pure understatement. Lots of people will not recognize the "special", but that's what understatement is all about. Great idea!
http://www.abload.de/img/dscf2044x4e.jpg
looks great :)
small thing,
turn those cable ties behind the barb will cleaner ( the bit where you cut it ) face it behind the barb
Hey disrupt (I repeat: I am your fan :D),
Steffen will take them off!
Steffen: Take them off!!!! :D
With the extra pics i'm actually coming to like it much more.
Is the tubing 3/8"ID or 7/16"ID? And are the barbs 1/2"?
Do you gonna watercool northbridge?
http://murderbox.com/uploads/DSC_5413.jpg
Don't worry, this one is for your wall - the one for your case still has the protective paper coating on. :D
The faceplate is done and at the Anodizer. With a little luck, you may have this stuff by the end of next week. :)
Oh Charles that pic makes my heart flutter :ROTF:. I'm in love:p:. In the nicest possible way, hurry up and get murdermod going!!!.
Sorry 'bout that minor outburst, i'm getting a bit carried away. I can't wait! :up:
LOL I could see us doing something stupid like a group buy [Disruptfam, you and moi] of MurderMods.
:party:
[Not really .. . .shipping .. . . will be like 300 for a Silverstone box]
Can't you guys get TJ07s locally? If so you can just order the bits that will ship in a nice cheap(ish) package and put it together yourself. That's what's taking so long - we're making sure all the mods are easy, grief-free bolt-ons. :)
If you can't get a TJ07 locally then that's a tragedy... pure and simple.
At least you don't have to pay a huge amount for PCC to ship it to you. I think I would just have the normal window but have that side against my wall so I can't see it.
EDIT : Nevermind, StaticIce has found some QLD stores for me :D
Charles - I am not sure whether to thank you or....my partner has taken one look at these builds that you have been involved in and said "why don't you make yours look like that...oh and while you are at it build me one!" :yepp:
So looks like when murdermod is online I will be buying pieces in qty of 2!! I must admit this waiting game is hard....
Steffen the build looks amazing....keep it up:up:
Hey :)
Whenever something is riveted, you can drill the rivet out and rivet it back together - as often as you like. Just use a drill that does not make the hole bigger, better start with a smaller one and "step up" until the rivet falls out. Then you have found the right drill diameter for the future :) 3mm is what usually works. At least it did on all Lian Lis and the Silverstone TJ07.
Modular or non-modular & sleeving: On a full-modular PSU (with also modular ATX 24pin), you can send in just the PSU in case of RMA. The warranty related issues are the only concern when it comes to sleeving. The technique is the same. On a modular PSU you have the advantage that you can just work on the wires with no PSU at the end.
Me personally, I have sleeved modulars and non-modulars. All the same :yepp:
@murdermod-shop: I rush to finish the shop, but we still need to test and test and test.
@Steffen: 0001 :D
this is one of the most beautiful builds ive ever seen... absolute beauty.... cant wait for updates...
nice job ;)
Steffen is it finished?
No not yet. Waiting for the last two parts.
Then i´m maybe finished :D
So so so. A few updates. Changed the complete colorscheme. The 790i board looks awesome but what use has it, if it performs like :banana::banana::banana::banana:.
So i changed a few things. For example a new mainboard, new tube etc. A few pics for you guys :)
http://www.abload.de/img/dscf20729yout6.jpg
http://www.abload.de/img/dscf20689af.jpg
http://www.abload.de/img/dscf2067hx2.jpg
http://www.abload.de/img/dscf2069hx8.jpg
http://www.abload.de/img/dscf2070idz.jpg
http://www.abload.de/img/dscf2074zil.jpg
nice shots Steffen! :up:
What was wrong with the 790i board?
Way to hot under load settings. The fan of the board was also to loud at 10%.
And the overclocking was pure bullpoopie. I tried to overclock my RAM and set the timings
a little bit lower and my windows completly crashed. Every time a overclocking failed i had to reinstall windows.
Thats some bug in the chipset. The new asus board with the x48 chipset works like a charm :)
