@koda,
Well, the good news is that the USB flash method worked perfectly.
Congratulations on an excellent application!
Thank you for all your efforts.
@koda,
Well, some users (Arctucas here & Litean on my forum) found that the new CD version don't flash the nvidia based boards (but USB version is fine).
So i worked hard today on this method (again :D), modified a bit, tested, tested & tested ... (USB & CD version) ... and it seems (at least) to work correctly.
So new release with Update to 0.71 for USB version and complete v0.71 CD version.
This v0.71 adds P5Q-Pro 1613 & Rampage Formula 0701 too (minor release for new bios) :D
Download links
USB Key version : v0.7
CD Version (ISO) : v0.71
Patch/Update links
Current version : v0.71 (must be apply on v0.7)
Well, feel free to report problems.
Regards.
Hey Koda how can i add the new 1302 bios for the maximus formula?
http://www.xtremesystems.org/forums/...79580&page=302
Never mind i used winimage to edit one of your .imz files,i removed whatever .rom file was there and put the one i wanted then i saved it has a new file.
http://i48.photobucket.com/albums/f2...mapImage-3.jpg
Okay,
Just keep the name of the file or edit the autoexec.bat ;)
Well, i got half dozen of new bios ... still waiting a bit before v0.72 (i can't release a new one each day ;)) :D
regards
Thx Koda for this tool will try to get the borked 1611 to 1406 flash working again as I have some issues with it now see this thread :
http://www.xtremesystems.org/Forums/showthread.php?t=210753
Flashed the bios with your tool and everything is back to normal ... could it be as it also erases the boot block ?
Thx man for this nice app, would be nice to see some other brands in ya nice program :) TOP JOB
New Fast Update to 0.72 for USB version (must be apply on v0.71).
This (small) v0.72 adds :
P5E 1102
Maximus Formula 1302
Maximus Extreme 1202
Maximus II Formula 1802
Rampage Extreme 0121
Striker Extreme 1701
Download links
Patch/Update links
Current version : v0.72 (must be apply on v0.71)
Older version for v0.7 : v0.71 (must be apply on v0.7)
Regards.
where are you koda
waitting for your new release
some bios are appear from your last tool version
I am having trouble getting the syslinux part to work....
When i go to the "INSTALL" directory via the windows cmd prompt and then type syslinux -ma E: , i get the following message:
Accessing physical drive: Access is denied. Did not successfully update the MBR; continuing...
Then I'm taken back to the INSTALL directory.
Any idea why this is happening???
EDIT: I'm on Vista 32
Are you running the command promt with elevated privileges (a.k.a. "Run as Administrator")? If not, that might be the reason.
Also, make sure your pen drive is unlocked (some of them allow to disable writes through a physical switch), AND you're using the right drive letter (the "E" you refer to is the pen's letter driv, right?).
That should work. If not, probably only koda can help you.
Cheers.
Miguel
__Miguel__ is right ;)
Are you sure to use the right letter for your pen drive ???
amazing tool !
very easy and work well.
tank you very much :)
i flashed my ASUS P5Q Pro form 1613 to 1406 and now i lets see if i can get my OC stable.
Huge Update with this v0.8.
Now the key is ready to flash more than 550 bios for 50 mtherboard's models.
the v0.8 adds :
P5Q-C 1806, 1702, 1613
P5Q-E 1901, 1703
P5Q PRO 1613
P5Q Deluxe 1805,1702
P5Q Premium 1611 ,1406
P5Q3 Deluxe 1901, 1702
Maximus II Formula 1901, 1702
P5E3 Premium Wifi-AP @N 0704
Rampage Formula 0803, 0701
Rampage Extreme 1003
P5E Deluxe 0304
P5E64 WS Evolution 0802, 0701
P5E 1201
P5E64 WS PRO 1102
P5E3 1301, 1201, 1104
P5E3 Deluxe 1409, 1405, 1404
P5K Premium 1101, 1001, 0901, 0802
P5K3 Premium 0807, 0805
P5K Deluxe 1005, 1004
P5K Pro 1303, 1202
Blitz Formula 1601
P5K3 Deluxe 1203
P5K64 WS 0701
P5K-E 1202
P5K SE EPU 0501
P5K WS 1102
Commando 1901, 1802
P5B Deluxe Wifi 1238
Striker 2 Extreme 1202
Striker 2 Formula 2001, 1901
Striker 2 NSE 0805, 0702, 0601, 0505, 0406
Memtest86+ is now the 2.11 version.
Download links & detailed contents on post #1.
You need a 1gb usb key now.
regards
PS : nickless, you will find what you need in this one ;)
very good work man
I would just like to say => thanks man :D
bumpage
Thanks for your efforts koda
I have noticed that ASUS have released a P5E3 Pro motherboard which is a spiritual replacement for the P5E3 (standard) as it also has a 1MBit BIOS image.
Is this going to be supported in a future tool and would cross flashing be possible? (even though the P5E3 uses the X38 chipset yet the Pro uses the X48?)
John
John,
well success with this cross flash (P5E3 into P5E3 pro) depends upon the difference between PCB & components.
If there is not really big difference, this could be possible.
About supporting P5E3 Pro, i will look if i can release a new & maybe last release for 775 socket.
Some people asked me about 1366 socket, i can't atm because i don't have any Asus x58 mb in my hands.
It is not very serious to release something that you didn't test ... it is very hard to release versions without any "guinea pig" board ... if any Asus PR read this ;)
Thanks Koda
Well looking at the board layout and manual for the P5E3 Pro it does look practically the same, the only difference is the P5E3 Pro has "Express Gate", P5E3 and P5E3 Pro both have 12VATX connectors instead of EPS12V connectors like other P5E based boards and they both have the same number and position of PCI and PCI-E slots.
P5E3 Product Page
P5E3 Pro
John
Can I make a "Lite" version of this tool? :surf:
Ket,
Any help is welcome, please PM me and let me know which mobo do you want to be in charge ;)
@Koda,
I was wondering if you were planning on expanding KodaKey to include Asus' X58 and P55 motherboards?
Thanks again for a great app!
Hey Arctucas,
not for the moment because i don't have any Asus board with theses sockets for deep testing and got some serious health's problems for a few weeks.
regards
