nah... it will be anohter 6 months before the buff comes then goes away for another 6 months...
I plan on playing Duke Nukem Forever before this unit is in stores. Too bad there is no reason to give for the extreme lateness of the Cryo-Z. I imagine it must be something very, very embarrassing for OCZ otherwise why not explain to us why it's been delayed so many times? Also why does OCZ even list it on their website?
OCZ didn't take any customers money in advance,no one is out a penny. The only thing they may be guilty of is raising expetations of a delivery date and not meeting them. Maybe someones feelings are hurt but no ones Bank account is.
In reality the only one out any dough is OCZ themselfs . You guys complaining ,how would you feel if you paid for a unit in full and a year latter are still waiting.......like many others......
Give OCZ a little credit.
Been available for a while now. As much complaining as there has been driving to pick it up shouldn't be a problem.
OCZ Cryo-Z
Yay if its true, love the max stable load of 120W, woohoo for overclocking celerons! :)
I saw several Units at Central Computer's Stevens Creek location in San Jose, CA. So They are out there, And they are in stores.
I might be receiving one of these for review. Right now it's only been hinted in a "what would you think about reviewing an OCZ Cryo-Z" to which I initially responded "why would I review a project that was canned". I'll check tomorrow to see if I can still get my hands on one of these. If so then I'll give it a thorough run-down and then tear it to pieces :up:
I think it would be great for a gpu.
so even at only 120w capability what would the temp be at 5.0 loaded penryn ??
would it still keep sub 0 ?? -10 ????? anyone..........
lucky me in Arizona but still 200.00 in gas in a cage to get thier
guess could strap it onto the bike for 80 bucks in gas
I got me one of these machines.
2v on qx9650 and it is still frozen at -10c
wow that sounds good ! thx
Pics because it happened.
http://img.techpowerup.org/080830/1264.jpg
This piece is very big, I had to cut some of it off to fit between the chipset heatsinks on my motherboard.
http://img.techpowerup.org/080830/2819.jpg
Those 2 fans IMO put out more noise than this phase does.
:up: thanks for the pic's
That's actually not good, that simply means the temperature setup isn't reading properly.Quote:
Well that's inside my bios, and with speed fan.
With real temp it is still frozen and shows no movement I have pics, but they are on my other HDD that decided to die on me....and this chip does not like to go past -10c no more. I need to RMA it.
I'm waiting on a e6700 on loan but it didn't show up today.
In bios? That's a no load shot, really almost doesn't matter what vcore your running then.
well it's the same in windows.
I don't know what the load is off the top of my head, but it does heat up when you start working it. I think it was around 30-40c on load.(I think 50-50)
Best was to run it around 1.6v 1.7 and the quad at 4.5Ghz
This was stable for the most part.
like I said my temp shots are on the dead HDD.
http://img.techpowerup.org/080830/12121.jpg
I did find this one. This is at 1.41 I don't think this is load tho.....
Wait positive 30C?
I digress - i told him that was a no go...
For 800.00 you could buy 2,make a copper spreader block mount both to one CPU IHS and get @ least 240 watts for 800.00. one unit fails you can still run your rig.
A lot of guys are charging more than 800.00 for just promises of 240 watts, any many of those are un-kept.
I bet they lowered expectations a little because ambient environment affects temps.
They also say 0 watts @ idle, Well unless the the head and the suction line was in a deep vacuum chamber there is never a 0 watt load........ ever on the head........Even a cpu @ idle has a heat output.A head sitting in air extracts heat.
I don't think they ever intended to make a extreme phase unit,but a introducty one where one can move from air or just plain water. A First step into phase. for a very good price.
BTW: Don't throw Stones if you live in a glass house, Did Confucius say say that ???? LOL. ;)
I've found the trick in the end, is to have all the stones ;)Quote:
No the trick in business is never give anyone a reason to throw a stone at you, then you'll do well....;) And you won't have a pile of useless stones . :yepp: And if you work hard and treat people fair, you may even end up with a gold brick or two...........:)
:up: thats how it works ok .. at least with me :D
heck a used unit ( chilly's , vapo's ) gets 350 now daze & may not fit your set up without extra money throwen at it .
and a TEC set up after all is said & done will run ya at least 400 bucks ( with the good stuff ...artic spider and meanwell ect...)
to have a good starting unit in ss for this amount is great !
let alone haveing all you need to mod later ;)
