I can provide high-res macro shots of areas you would like to see. I am pretty much at the end with my skills with this card. I never had a video card that was that strange in my entire life. =)
Thanks a bunch, but I think I have the close-ups I need.
It's like the documents about this damned phase chip would've gotten censored off the whole internet...
Indeed. I thought I was the only one not finding any tech sheets.
For chinese version Gainward 9600GT 512M Redflag version H
http://img2.fj007.com/news/2008/4/20...1155368725.JPG
http://img2.fj007.com/news/2008/4/20084131116924335.JPG
And sorry i have lost my faith for 9600GT refrence PCB.....
so wha tvoltages is everone running - and cooling type?
Pin35 is not OVP, I have tried
with:
http://img293.imageshack.us/img293/5275/fehleryn4.jpg
(....electricity is not enough....)
so currently I am on very good A/C air with both cards (S1 rev.2s) and water on the CPU here is a score that isn't my best or best yet :up: these will do 845/2112/1000 no problem w/ both on 1.3v (I believe) and no RAM mod
Just read through this thread. Has ANYONE managed to get the reference PCB mod to go above 1.45v or so? Going to put these cards under some dry ice and was hoping they'd scale to 1GHz+. Is it an OVP/OCP issue or a cooling issue? Haven't seen any definite answers yet which is disheartening.
I cannot get past 1.21V bedore the OVP kicks in with my reference design based card.
I tried a lot of different things without success and I think I will submerge the card in LN2 and get a decent card.
Pardon,
Is there any pencil mod for this card?
Regards,
Abang_apy
I have a pair of leadtek winfast 9600 gt extreme video cards. They are water cooled with danger den maze-5 blocks and coper mem syncs. Would the pencil mod in the last post work for my card? What voltage would you guys recommend? Last question: in the last post, the 3dmarks score of 13490, that is one card right? I have two cards and only 4000mhz c2d and I get 15500 with stock video cards?
Prelim , only the black spot :up:
so here is the dumb question...
how to trace it with the pencil, if you have the naked pcb between the contacts? :confused: :confused:
1.3815v mod listed above confirmed working on palit sonic 9600gt.
benching 3dmark05 now at 900mhz core linked shaders at 21xxmhz wasn't paying attention to exact number on shaders. previous highest benchable core speed was 833mhz. but that wasn't gaming stable, after an hour or so it would freeze up requiring a hard reset. if i tried setting 845mhz or higher it would either lockup or blackscreen reboot.
so i'm happy to have found this thread while i had my machine tore apart for a paint job and was able to compare the pics to my card.
that rig is setup where i cant stretch the Internet wire to it. so for now i'm not going to run 3d06 or be able to post screenies. but it is almost done with 3d05 900mhz core so stoked. i'll wait a minute to give you my score.
that rig has a abit p35-e running a e2180@3.5 2gigs of tracers at 1050mhz.
had to break out a cat5 cord to see my score lol 19295 on 3dmark05 i made the second page out of all the 9600gt's whee!!!:bananal::bananal:
12425 on 3d06
http://img175.imageshack.us/img175/6374/vmdto2.jpg
By rangerone7669 at 2008-05-03
about the most i can push at 1.38volts. anyone tried 1.43 or 1.45volts?
Vmodded my Palit cards to 1.38V and got these magnificent result on air :up:
VGA Cooler: Thermalright V2 + 9 cm 0.3A fan
CPU cooling: Enzotech SCW-1 + MCR-220QP + MCP-655B
http://i168.photobucket.com/albums/u.../96gtmaxoc.png
very nice!!!:D:clap:
does anyone know how to calculate the voltage?
i've an 88GT non reference layout using the same chip
http://pix.nofrag.com/2/4/7/3050624d...fa126f1a75.jpg
http://img404.imageshack.us/img404/6004/vidwb7.jpg
the datasheet of the chip is here
DataSheet RT8802A
can anyone calculate my current voltage from the picture above and say me the settings for maybe 1.3 volt?
Can some one help me to find points for vGPU.
This is ASUS 9600 GT but with blue PCB.
http://www.fotorola.com/uploads/1f75d506f3.jpg
http://www.fotorola.com/uploads/302b652fb9.jpg
Thanks in advance mates!
Spacemaster,
Your card is reference design just with blue color. So basically you're SOL as the reference card has some serious problems with mods and load stability.
You could try the VID mod, but prepare to reverse to mod as extreme instability is more than likely...
Time for me :)
Gainward 96GT Bliss(red PCB).
http://img265.imageshack.us/img265/2016/p5160752es7.jpg
http://img362.imageshack.us/img362/8053/p5160759uv9.jpg
http://img207.imageshack.us/img207/7440/p5160830ml8.jpg
http://img524.imageshack.us/img524/1771/p5160833km6.jpg
http://img185.imageshack.us/img185/4782/p5160834qr9.jpg
Couldn't find any similiar PCB in this thread. I would prefer pencil mod over soldering. If You need a good macro shots of specific areas just tell.
Thank You in advance.
Edit: Gah, it's the same pcb as Vanilia on page 6, now only to find out where to smack it around a bit with a pencil.
