These things rock. I am using water. Haven't had much time to play with it, too many other things going on but..........
http://img145.imageshack.us/img145/7231/8hrspe1.th.jpg
3.8GHz @ 1.2V after 8 hours Orthos 38C max temp. I sure love it.
Nice chip Tarowah, max FSB? :)
Batch? ;P
Here is my Q807A091 , temps buggy but less volts than my Q746A534 :p:
4 ghz priming with 1.20v load
http://img155.imageshack.us/img155/5415/4hty5.th.jpg
Hehe, sounds good! :D
damn you all :P
Remember to start off using a a slow performance level if you use a P35 board (say 12). My DS4 + E3110 combo absolutely hates a fast strap. Even 9*400MHz doesn't feel completely stable (and sometimes refuses to boot) at performance level 7. Now at level 12 I'm working my way up to 4GHz on low vcore and everything seems fine. For this test I only use 2 dimms by the way, so strain on the chipset is kept to a minimum.
At FSB 445 my P35-DS3 uses Performance Level 8. Runs flawlessly for me :)
Maybe my DS4 is a freak then :down: Can you share your settings with me please? I'd like to know MCH, vFSB and secondary memory timings. I have MCH, vFSB and secondary timings on auto, which worked perfectly for me with performance level 7 at +-500FSB previously using an E6600.
can someone explain this performance level?????
Mhm, my settings are about the same.
-vMCH, vFSB, vPCIe -> normal
-sec. timings -> auto
-performance enhance -> turbo
I am also using 2x2 gb gskills (pc6400). Those are getting 2.08 vdimm (might be a tad to high but I'm too lazy trying around. buying new rams anyway..).
The latency between memory controller (nb) and your ram sticks. Short form. ^^
yes but in long form
level 1...
level 2...
:P
Long form...
http://www.anandtech.com/mb/showdoc.aspx?i=3208&p=6
http://www.anandtech.com/mb/showdoc.aspx?i=3190&p=12
Hope you've got some spare time :D
Who's got the Q807? Was that Tankguys?
Box: Q746A
Tray: Q805A
@tankguys..
There was a reason for me giving you the short form :p:
ok i'll figure it out...where can i see this performance level xyz...in memset?
Jep.
http://img.photobucket.com/albums/v3...1Apr082136.jpg
Working my way up at 1.344v, haven't hit the limit yet. Chip is C0 Q751A439.
*EDIT* 4.26GHz done :)
Ah, no - I don't have it.
Those are just 2 articles which are pointing out what static tread aka performance level is :)
I got my Q807 box from Tankguys last friday.
