NYRAD: is it 400mm reservoir?
here are some pics of some of my older LianLi V series builds...
Already posted in the LianLi V series thread but since they are watercooled i thought they could fit in this one as well...
Troopers V2000
http://i7.photobucket.com/albums/y27...%20V2000/1.jpg
http://i7.photobucket.com/albums/y27...PERSV20003.jpg
http://i7.photobucket.com/albums/y27...PERSV20004.jpg
http://i7.photobucket.com/albums/y27...PERSV20006.jpg
http://i7.photobucket.com/albums/y27...ERSV200010.jpg
http://i7.photobucket.com/albums/y27...ERSV200011.jpg
http://i7.photobucket.com/albums/y27...ERSV200013.jpg
http://i7.photobucket.com/albums/y27...ERSV200014.jpg
Project V2000 Shine
http://i7.photobucket.com/albums/y27...Shine/sp10.jpg
http://i7.photobucket.com/albums/y27...Shine/ext5.jpg
http://i7.photobucket.com/albums/y27...0Shine/sp6.jpg
http://i7.photobucket.com/albums/y27...0Shine/in1.jpg
http://i7.photobucket.com/albums/y27...20Shine/74.jpg
http://i7.photobucket.com/albums/y27...0Shine/cl8.jpg
http://i7.photobucket.com/albums/y27...0Shine/in9.jpg
Project V2110 Olympiakos Edition
(i know its not V2000 & V1000 but i think it fits in this thread)
http://i7.photobucket.com/albums/y27...casesketch.jpg
http://i7.photobucket.com/albums/y27...%20Case/17.jpg
http://i7.photobucket.com/albums/y27...%20Case/18.jpg
http://i7.photobucket.com/albums/y27...%20Case/20.jpg
http://i7.photobucket.com/albums/y27...%20Case/22.jpg
http://i7.photobucket.com/albums/y27...%20Case/23.jpg
http://i7.photobucket.com/albums/y27...%20Case/24.jpg
http://i7.photobucket.com/albums/y27...%20Case/26.jpg
http://i7.photobucket.com/albums/y27...%20Case/29.jpg
http://i7.photobucket.com/albums/y27...%20Case/28.jpg
http://i7.photobucket.com/albums/y27...%20Case/31.jpg
Holy Christ that last one was AMAZING! I love the spectacular red color coming off of the CPU-350!
indeed it is :)
Wow. Wowwww.
First post at XS :)
My current rig
http://sphotos.ak.fbcdn.net/hphotos-..._1448751_n.jpg
http://img.photobucket.com/albums/v97/tmwong/ex2.jpg
http://img.photobucket.com/albums/v97/tmwong/ex8.jpg
http://img.photobucket.com/albums/v97/tmwong/ex3.jpg
http://img.photobucket.com/albums/v97/tmwong/ex5.jpg
http://img.photobucket.com/albums/v97/tmwong/ex4.jpg
http://img.photobucket.com/albums/v97/tmwong/ex7.jpg
Phil
Lovely idea, that sidepanel on 5.25 bay enclosure side. Though flowery motive looks a bit out of place in combination with industrial look on the right from it :)
You forgot to cool the HDD(s)/SSD(s) and PSU!
Very purdy there tipgo.
Here is a P80 Armorsuit i've recently built.
One of the few cases around
that can hold EVGA X58 Classified 4-Way SLI
and a internally placed quad radiator without any major modifications.
This one in particular got a glossy black interior powder coating
a basic cable management, Koolance waterblocks and pump-res combo
and some aluminium sideskirts to partially conceal the wheels and fans in the bottom of the case...
http://i7.photobucket.com/albums/y27...P80-GTX480.jpg
http://i7.photobucket.com/albums/y27...g-GTX480-2.jpg
http://i7.photobucket.com/albums/y27...g-GTX480-3.jpg
What tubing brand did you use knet? Usually with light colored liquid in white tubing, the tubing becomes a bit transparent. The stuff you used doesn't show any signs of transparency...
Here are some photos of my upgrade/redo (the first major since 2007). The project is named for a famous text written by Danial Bernoulli about the mathematics and engineering of water flow (hence the name Hydrodynamica). The 'DS' stands for dead silence and the '3X' means that the build has three separate water loops (one for the cpu, one for the gpus, and one for the chipset, .. although, in this current configuration, the third pump is off and the XSPC RX 120 that would be used for chipset cooling is currently helping out on the ATI 5870s). The project produces 18 dB at almost exactly 30 cm and from three feet away is truly dead silent. It also features some custom work, including a special negative pressure airflow system with custom backplates to radiate heat, a rebuilt PhysX card with a custom circuit board add-on and passive cooling, a custom built handle on the XSPC dual DDC reservoir for pulling it out to add coolant, etc..... All three water loops and cooling are internal. Notice that I did not use a SLI bridge for the water blocks on the two GPUs, as this cuts flow and increases temps. It is not as decked out as some of the mega rigs I have seen here at XS, but then it is also not a show piece either. It is a day in and day out rig where I cannot stop operations just because Bitspower came out with a new color combo.
The temps are:
When flight simming or gaming; cpu ~41 deg C, gpus 44 deg C, northbridge 39 deg C, PhysX card 34 deg C
When running Matlab, finite element analysis or simulating neural networks; cpu 43 deg C, gpus 46 deg C
When running Prime95 on 12 cores (at the one hour mark); cpu is roughly 63 deg C
The current specs are:
i7 980X @ 4.4 GHz, ASUS P6T Deluxe Version 2, 12 GB Corsair Dominator @ 1866, 2 x 5870 (Crossfire), Ageia PhysX PPU card, Creative X-Fi Titanium Fatalt1y Pro, 2 x OCZ Vertex 120 GB in RAID 0 (Firmware 1.6), 2 x OCZ Vertex 2 120 GB in RAID 0 (Firmware 1.11), Seagate 1 TB, Thermaltake Toughpower 1200W modular, Lite-On 24x DVD burner and Pioneer BDR-205 Blue Ray Burner, Apogee XT on the cpu, MCW-80s on the GPUs, DDC 3.25 pumps, XSPC rads and XSPC dual DDC reservoir, Lamptron FC2 version 2, Scythe S-Flex and Yate Loon low speed fans, Logitech G510 keyboard, MX Revolution and Razer Mamba, Creative Gigaworks 750, Sharp LC-46D85U, Track IR 5 and CH Fighterstick/ Pro Franken Potato Throttle/ Pro Pedals
(some of the wiring and the speaker cables are run behind the walls for less clutter)
I know mine is posted in work logs, but I might as well post it here too! I have to compliment everyone here though, beautiful work!! :D
http://a.imageshack.us/img547/2671/p1010011r.th.jpg
http://a.imageshack.us/img80/8205/p1010012tj.th.jpg
http://a.imageshack.us/img339/8052/p1010020ar.th.jpg
http://a.imageshack.us/img715/378/p1010007dh.th.jpg
Hello
Here's my Lian Li PC-A77 :)
http://upic.me/i/xj/xq1i1.jpg
http://upic.me/i/4z/9u464.jpg
http://upic.me/i/tc/a6sc5.jpg
http://upic.me/i/0b/04lv7.jpg
http://upic.me/i/xp/gh468.jpg
http://upic.me/i/6w/wk711.jpg
http://upic.me/i/vx/i3o12.jpg
http://upic.me/i/ut/dvg13.jpg
http://upic.me/i/o1/vgc15.jpg
knet370 thats a really nice touch with how the tube goes over the cpu
Finished!!!
http://i900.photobucket.com/albums/a...d/IMAG1142.jpg
http://i900.photobucket.com/albums/a...d/IMAG1118.jpg
http://i900.photobucket.com/albums/a...d/IMAG1126.jpg
http://i900.photobucket.com/albums/a...d/IMAG1131.jpg
Need to adjust the wiring a bit but and waiting on the GTX 480 I bought from a member here otherwise done....:D
Still not finished going to change the CPU waterblock and take more detailed Photos of how the system is put together, and also some night photos as there are lights inside the system. :D
Very Nice @Farmerbrown
@ Farmerbrown - your PC is looking sharp in the snow. Good job on the photography.
