Originally Posted by
willyK
@ BadNizze - have you run memtest86 with those sticks at those speeds and timings with your 6400+?
Reason I ask is that I've got 2 GB Crucial Ballistix PC2-8500 paired with a 5000+ BE, and optimized default BIOS settings set DRAM voltage to 1.96 V and speed to 800 MHz. At these settings, memtest86 results come back error free. However, if I crank the voltage up to manufacturer's spec, which is 2.2 V, I get an error very quickly that halts testing.
800 MHz Crucial Ballistix is rated @ 2.2 V as well. Is it okay to run it undervolted, or is this just some artifact of memtest that I should ignore?
