My new LanLI G70
Used a Thermochill 120.3 with ACRyan Grill. Fitted fine and also Yate DS12 fans and a nice GTX block and DDC Ultra Pump. :D
http://www.overclockerzforum.com/php...cf0549_316.jpg http://www.overclockerzforum.com/php...cf0548_102.jpg
My new LanLI G70
Upgraded my watercooling finally.
D-tek Fuzion
Swiftech MCW 60
Thermochill PA120.3 (6 Yate Loon)
Iwaki MD-20RZG-2
1/2" Tygon R-3603
CPU 1.55v 2970Mhz : 30 Idle 40 Load
CPU 1.4v 2800Mhz : 28 Idle 34 Load
GPU 1.425v 725Mhz : 39 Idle 44 Load
Temps are averages by Coretemp and Rivatuner, in a 20C room.
I must say Im very impressed by the performance, absolutely great stuff. But the Iwaki is pretty loud, and hot. Maybe it's because I'm feeding the beast 110v from the 230v converter instead of it's rated 100v.
http://www.nietbelangrijk.nl/download.php?id=2357
Another thing is the ramsinks of the MCW60, theyre just useless. For straters they dont fit beneath the tubing and second they came off just by looking at them (but that I knew), so my mate TRG whipped out the dremel and cut up the stock 1950XTX cooler.
http://www.nietbelangrijk.nl/download.php?id=2351
And just a random pic to show that you should always clean your rad, or ban the cat from the computer room.
http://www.nietbelangrijk.nl/download.php?id=2337
Sure here are some more. Although its far from finshed at the moment, im waiting for a GPU block for my 8800GTS. I want the Black Swiftech Stealth GPU Waterblock.
http://www.overclockerzforum.com/php...c00211_192.jpg http://www.overclockerzforum.com/php...c00212_144.jpg
http://www.overclockerzforum.com/php...c00213_962.jpg
http://www.overclockerzforum.com/php...cf0546_130.jpg
here are a few pic's of my unfinished P180.
http://farm2.static.flickr.com/1092/...3f7e9f02_b.jpg
http://farm2.static.flickr.com/1342/...8d4a6bb7_b.jpg
http://farm2.static.flickr.com/1386/...a2bdc324_b.jpg
I still have some messy wiring and paint to touch up... as well as the Gpu to add onto the loop
