The GTX OVP mod is post 1 of this thread :)
http://www.xtremesystems.org/forums/...d.php?t=162124
i've no luck for my GTX...1st batch...
get frezee anything above core =695mhz
no effect from 1.5v to 1.6v
dun dare put above 1.6 cause on water only
mem also limit to 1035 not much effect on mem vmod....
i guess OVP not for me ....
btw is anything overclocking protection for GTX ?anyone can answer this...?
hehee, if you are using stock, you shoud try a better cooler, - Thermalright for ex.
http://www.xtremesystems.org/forums/...&postcount=234
This is OCP, not OVP.
adding the caps in parallel to the existing caps provides extra filtering of the gpu voltage. However this only comes into play at voltages above ~1.5v. Adding the coils im doubtful would help at all. Adding the caps (& coils) wont give you a better overclock alone, but are meant as a supporting mod to assist running high (1.5v +) gpu voltages.
True, this can and has be done for many other hardware in the past, still it is not the best way to get rid of OCP.
I've moded 4 caps only helps the cpu overclock ...
b4 the vcore of cpu wasn,t stable jumping between 1.488-1.502...
after i put on caps mod it stable at 1.488
it benefit my Q6600 from 3.6 to 3.85 stable now.
but not helping for gpu overclock....
weird...
So for 8800gt/gts g92 mod's the same?
Little bit confused with so many pics :rofl: ...
Ocp makes the vga no longer "shuts" down ???
Clear pics would be great
OCP for 8800gt/gts g92 this one?
http://img264.imageshack.us/img264/4...00gtocpxa2.jpg
Ovp no luck so far correct?
Possible to prevent the card from the shut off without taking the resistor off?
Can we add a vr at one side of the smd and adjusting the pot to neutralize the value ?
Or maybe pencil mod for ovp
OVP works at home (1.62V burn OK). But OCP doesn't work (last explosion for Aquamark is the best test for it).
Any idea for OCP removal ?
http://www.xtremesystems.org/forums/...1&d=1198824594
Removed, add a pot or penciled the bastard ? :D
:up:
Hmm, to cancel OCP, do I have to unsolder the 2 little resistor surrounded ?
Sorry for nub question guys but do these work with G92 GTS also ? Is there a thread on my card ? What is the difference between OCP and OVP ? Which do I need on a water cooled card ?
Any help would be great.
:up:
Up : how to cancel OCP on Primarion 3544 controller ? 8800GT for me.
I have an old A2 8800GTS-320. I tryed to pencil the assigned resistor (post #7). I lowered the resistance to 4,75 KOhm as you said. My default VGPU falled back with ~0,1 V. I started to turn down my soldered resistor (for VGPU mod...) until 1,45 VGPU and gained some extra Mhz but OVP (or OCP, I do not know what is the correct word) turned down my card during 3DMark.
Does anybody tryed it with success? Which is the good resistor and resistance value?
janos666,
It's possible your card is tripping due to OCP.
G80 OCP mod can be found here.
You need to solder some SMRs on couple of SMCs.
http://www.xtremesystems.org/forums/...&postcount=546
Basically it's the same as G80 OCP mod. Just different locations.
as per PM, measure which side of the SMC is grounded and attach the negative to that.
Hi,
There is a lot of different ovp mod, i'm not sure that every one works perfcectly.
Did anyone find it and can set 1.6v on gpu ?
I need it, LN2 is coming last week so i don't want to be stuck at 1.4v.:p: Please help me!
Thanks ;)
I never had any luck in raising OVP
So how do you get 1.1Ghz + on a GTS 512 ?
