I added two fans to the window of the case and tidied up the wiring a little.
(Check Below, I had made the pics too big, I pulled them so it's easier on the eyes, smaller versions below. )
[QUOTE=Grinch;2543663]ahhhhhhhhh easier to see....
How do you think it looks?
http://img98.imageshack.us/img98/9527/pict0037ci9.jpg
Could of used varrius's help with mine :rolleyes: :p:
Oooh, I didn't even see that. I love my rocket v team. :up:
Ghetto !!
OCZ cooler cpu duct lost in space. Bits of old masonite stuck in there. You're sure you're not the open test rack kind of guy, rather than a closed case guy?
outblast downsize your pics!!! please do not pic quote him!! 2 big!!!
Well yea i need to rearrange some stuff there i dont have to much room to move the enermax because i have an Antex true power 530w sitting on top of it. they both get plenty of air and explel it out the back. Ive got these really cool lian li side ducts (hard to find) that devert psu air to the side in the back away from the radiator.
Im getting good temps now but I opted to get another 3X120mm rad which is on the way, for good measure. Since taking this pic I lowerd the cpu voltage to 1.35 and found it to remain stable.
http://img142.imageshack.us/img142/3...rloadedib0.jpg
I got rid of that ocz fan and put it over the memory. I have 1/2" aluminum sinks on my ram ;)
Iv got custom sinks on just about every thing; to answer the question above..I made this cool air duct with a 80mm fan attached to replace where the ocz fans position. Ill take a pic shortly.
indeed ima avid mountain bike rider. Just went through 2 $2500 SantaCruz frames that snaped in the same place whith in a year and 1/2. long story but im not in the least happy with the company. Great bikes though while they lasted. Just got enough saved up for a Specialized demo 8 bike which is AWSOME btw. not to mention the frame has a lifetime warranty.
I got a nasty sproket injury so iv got some time to work with my comp. gonna let it heal up a bit allthough ill probably be back riding tommorow.
http://img69.imageshack.us/img69/2474/wound008xi0.jpg
http://img162.imageshack.us/img162/6...104420adj7.jpg
Ill post back with the cooler i made:) Ohh heh in resonce to the "ghetto" coment. Look under my cars hood..every thing might not be super tidy and polished but ill bet ill bet any body on the block :D
pzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz zzzzz
... and that is why i'm running 22/32/bashguard... no thanks to hamburger shins :P
Nice, let's turn this into a hybrid lili/MTB thread. :rofl:
Tornado 92mm on the cpu and 4 Thermaltake SmartFan 2's. This was the loudest case I ever had....still unsure what was wrong w/ me. :D
http://img.photobucket.com/albums/v2...Fans_TTSF2.jpg
Much quieter and better looking. :up:
http://img.photobucket.com/albums/v2...vie/v3Side.jpg
Mt Eldon in Flagstaff, AZ. Considering I'm from the valley, the lack of air really got to me. :( After paying the price, we received our epic downhill prize. ;) (for a xcountry guy anyway)
http://img.photobucket.com/albums/v2...IMG_1057-1.jpg
Night riding on South Mountain.
http://img.photobucket.com/albums/v2...B/IMG_0867.jpg
Here's a couple of questions for the v1000 & 2000 owners. I have this case:
http://www.xoxide.com/lian-li-pc-v2000aw-plus-2.html
1. Which way do you have the fan oriented that's mounted by the pci slots?
2. Which way do you have your PSU mounted in the lower chamber?
3. Or which way do you think they both should be mounted to keep things the coolest?
I have 1 intake fan on the lower and upper chambers on the front of the case, 2 80mm exhaust fans in the PSU chamber, and 1 exhaust fan behind the CPU and the PCI slot/side panel fan.
I have also figured out that by removing the black mesh that they ship on the rear fan, my cpu temp seems to have dropped by between 1 and 2 degrees. It's not much but it's something.
Hey, so i decided to rebuild everythinng after reading some of the users feedback. I have an extra 1x120mm rad laying around that im going to through into the loop but im really not sure where to tye it in at or place it. much help would be appreciated. Ive overvolted my pump which spins like crazy so i should have plenty of presure. Any sugestions?
http://img81.imageshack.us/img81/260...0037ci9yb5.jpg
My new V2000B PlusII after TJ07 :D
http://img160.imageshack.us/img160/4104/13bt0.jpg
http://img240.imageshack.us/img240/8492/26810672qs0.jpg
http://img219.imageshack.us/img219/1306/15549264db9.jpg
http://img219.imageshack.us/img219/6525/63635171tq1.jpg
http://img251.imageshack.us/img251/1161/59678077ng5.jpg
http://img219.imageshack.us/img219/9575/16010182ma4.jpg
http://img217.imageshack.us/img217/4079/12894760vb0.jpg
http://img215.imageshack.us/img215/3482/42698375gr3.jpg
Wow Man i love your build so clean and sexy!!!
I wish my psu cable's were long enough to go behind the mobo :(
then i could get is as clean as yours
awesome work man!!!! I'm jealous!
hey did you cut a hole in the bottom for airflow for your rad???
I should be finished with my v2000b + in a week or so... just waiting on screw's of all things :(
Thanks ;)
No I didn't cut the bottom.
http://img138.imageshack.us/img138/1010/12iu4.jpg
I used stock case for now my project begins after christmans ;)
ok :) how's the airflow ????
What are temps like???
cheers
Airflow is really good don't worry about this.
Q6600 B3 @ 3.5
36-36-38-37
@%100
49-50-50-49
Like this room temp 23 C ;)
awesome.... what are you gonna do for your new project??
Suprise:D
