Well today my new pump bracket came, props to Tom @ ChilledPC - it's perfect.
Pump bracket on it's own.
http://www.meknet.co.uk/PC343B/PumpH...4012008031.jpg
Back shot showing the grommets for anti vibration purposes, with M4 screws going through:
http://www.meknet.co.uk/PC343B/PumpH...4012008033.jpg
Holes at the back for air flow:
http://www.meknet.co.uk/PC343B/PumpH...4012008034.jpg
Front shot showing rubber washer for anti vibration and dome nut on the end of M4 bolt:
http://www.meknet.co.uk/PC343B/PumpH...4012008035.jpg
Print of 1:1 Autocad drawing:
http://www.meknet.co.uk/PC343B/PumpH...4012008036.jpg
Bit o' double sided sticky tape where pump holder will stand, then stuck to the black neoprene underneath:
http://www.meknet.co.uk/PC343B/PumpH...4012008037.jpg
Craft knife and scissors (for corners) later:
http://www.meknet.co.uk/PC343B/PumpH...4012008038.jpg
Tomorrow, time to plumb up :up:
P.S Tom, I love you.
