Thanks for the info :)
I always thought that using fans to minimalize the amount of condensation was the way to go. How do you insulate the socket area to prevent condensation?
omg >5700mhz 32m is out of this world :eek: congratulations from here as well for the sub 9min 32m. Looks like you have the best chip, equipment & skills around the world at the moment - simply godlike what you're doing these days :clap:
Thank you always, SoF-san :toast:
I use papers and masking-tape like this.
http://homepage2.nifty.com/NewBeetle...IMM_socket.jpg
And FAN Controller
http://homepage2.nifty.com/NewBeetle/FAN_Controller.jpg
DEWA DEWA, massman-san
NewBeetle
nice tips nb-san, :up:
btw.. u didnt use lacquer spray or nail vernish?
only masking tape?
I don't remember if I have congratulate you in this thread too :D so congrats one more time M8..... :D :clap:
Congratulation beetle san.It's wonderfull score.
That's quite a lot of copper Newbeetle, thanks for the explanations.
I like your pot newbeetle-san:up:
Thank you so much, the-strokes-san, hipro5-san, asterix34-san, Stapler-san, Zannema-san :toast:
No, I didn't use them.
I use not only masking tape but also paper towel. :D
The paper towel is very important.
It has high adiabaticity and absorbs the drop of water. :cool:
I use it with matching the shape of the socket.
Thank you aways, hipro5-san :toast:
And congratulations on your 3DMark06 WR!!! :toast: :toast: :toast:
I am looking forward to your result on Wednesday. :up:
DEWA DEWA ~
NewBeetle
Many thanks all!!! :toast:
Wow! Your new CPU is the fastest E6700!!! :eek:
But it may not be E6700 because it shows x31 multiplier. :D
Watercooling on NB, I can run @FSB615NHz. :)
But using LN2 on it, NB is freezed. :(
Using dry ice and adjusting the temp (-)10C-(+)5C, I can run @FSB635MHz.
http://homepage2.nifty.com/NewBeetle...an_1st_800.jpg
http://homepage2.nifty.com/NewBeetle/6x635_P5K.png
Thank you so much, luihed-san. ;)
I have not forgotten your word.
I was able to receive a very fast CPU from the overclocking gods as you said. :D
DEWA DEWA ~
NewBeetle
Thats a nice boost. I may have to look into making some sort of pot to try it out.
Hi, filmbot-san and all :)
I tested Dry Ice-cooling for the chipset.
32M might run by FSB620 or more if holding out a little more. :D
modPI 8M new WR : 01m52.937s @5590.0MHz (FSB621.1MHz x 9)
http://homepage2.nifty.com/NewBeetle..._01m52s937.png
modPI 16M new WR : 04m10.437s @5559.5MHz (FSB617.7MHz x 9)
http://homepage2.nifty.com/NewBeetle..._04m10s437.png
(Set up)
M/B:ASUS P5K Rev.1.02G VMod (75MOACD45***/P5K0408.ROM)
M/B Bed:「V-TEC ARC Bed Rev.3.3」
NB cooling:Tara-chan 1st (mini copper pot) + Dry Ice/temp (-)10C-(+)5C
SB cooling:Swiftech MCX159-R + FAN + Torii-kun-mini (by Tam)
CPU:Intel Core2 E6700(L633A549#7)
CPU cooling:MaxxNEO + LN2/temp:-155C
Memory:Team Xtreem PC2-8500 C4 1GBx2 4-4-4-4
VGA:Matrox Millennium PCI 2MB
HDD:Western Digital WD360ADFD
Power Supply:OCZ PowerStream 520W
Vcore:1.830V(Actual)
Vio:3.50V(PC Probe 2)
Vdimm:2.65V(Actual)
OS:Windows Server 2003
Remarks:FSB550MHz x 9@boot
http://homepage2.nifty.com/NewBeetle...+Tara-chan.jpg
great great newbeetle :shocked: :up:
VMCH ?
^Apparently we have different definitions of good.
I feel like I am sitting in on a master class of Sub Zero overclocking and benching :up: :clap: , New Beetle-san you are a great teacher and your willingness to share your experiences and knowledge is greatly appreciated by me and I am sure by all members here. May Team Japan and all its members prosper and continue to have good luck. Thank you.:)
Congratulations,more two WR::clap: Fsb 620 Mhz.:shocked: great work,bravo Newbeetle san
OMG!!! Extremely nice, congrats:up:.
Youre welcome :).. I have an E6700 coming ( L626B ), maybe you can wish the same for me ;)
I tried using dry ice on the chipset and my commando's max fsb on 1066strap went from 490fsb to almost 520fsb... but my pot was just a nb cooler with a bunch of dry ice on top lol.....
http://www3.telus.net/luis99/oc/nbcooled.JPG
I notice that NewBeetle-san is only running the northbridge at -10C, so it doesn't seem like that'd take anything too elaborate.
Whatever works,right. :D
I love seeing xtreme northbridge cooling. The only time I tried it was on an i875 board...don't have any two containers that can fit properly atm on new boards. :-/
Congrats on new WRs NewBeetle! 9x617 runs are just awesome! :clap:
Why did you go back to P5K from P5K-E?
