guys, i have a Q. whats your core temps at theese speeds? i mean stable.
i try to search if volts or temps are limiting me... i dont want to run this all day at 1.6V... imagine that power consumption, i found sweet spot at 1.39V 3.18Ghz
You got me Biohead :p:
I haven't opened that link.....
I was to quick with my post LOL!!
Still some information is missing .... like memory voltage, etc...
Congrats SAD! Awsome result with those X2 6400+'s!!!
Phase?
WR next one of you!!
Edit: Got the stepping for that one?
where you guys bought these Jh-F3 chips from?
All 5600+ to 6400+ are F3, (ie CZBOX), so no troubles there, no need to check first.
The chips that may or may not be however are:
5200+ (all 65watt versisons are so that's a giveaway)
5000+ (may also be 65nm - brisbane)
4600+ 65watt
3800+ 65watt
AMD X2 6000+ @ 3.65GHz / Inbox
Damn, its really hot with inbox cooler:ROTF:
Hey folks.. sorry for the VERY slow response. I am rarely online during the weekend.
Ok.. for the critical questions:
Chip: AMD X2 6400+ Black Edition
Stepping: ACB8F 0723 (damn.. forgot the last part.. i think SPWM)
Mobo: DFI 590
Ram: 2GB OCZ 8500 SLI Edition (didn't oc these yet)
PSU: PCP&C 750 Quad Slincer
GPU: EVGA 8800 GTS 640MB
Cooling: Approx -10c using Single Stage Phase (Ghetto modified for those temps)
All in Danger Den Torture Rack
Cold Bug limits me to around 230Mhz FSB when evap pushes over -26c.
Processor actually performs worst for me when more vCore is added (over 1.65 vCore).
Ok.. I hope that help.
mAJORD - Hey you mentioned about some friendly competition on the 6400+.. well.. lets not compete against each other. I am focusing my attention on HWBot and tryingt beat the overall X2 / AMD WR. This is goingn to be pretty fun trying to attempt that. So lets work together to see if we can set a higher bar for AMD.
SAD
nice nice 4ghz :D
With some luck a few cold loving 6400 wil popup and 4.3
might be doable at 90nm old K8 tech lol :D
Compete wasn't the right word, I did mean work together yes. ;) but settign eachothers new clock as a target allways makes it a bit more fun and a reason to bother so to speak.
I too don't care who does it I just want to see the WR broken :)
PS I found the same with added Vcore, especially since i'm using a pelt so it only served to increase temps.. 1.62ish awas about where it really stopped responding regardless. :)
mAJORD - Cool.. that sounds like a plan :) Lets see what we can do to break the WR. So what is your stable 1MB Spi Speed? So far I'm at like 3.7'ish.. haven't tried to any hard yet.
It would be cool to break the 20's barrier :D
SAD
SAD:
Best so far
22.7 3.8Ghz +22c Load.. dropping the temps will be the thing here.. as you can see the ambient water and too smaller pelt just can't keep it cool. makeshift water chiller is in the works.
http://www.xtremesystems.org/forums/...&postcount=168
Just a quick update. Had time to play with the Black Edition last night. I was focusing on tweaking the systems a little.
The best Spi 1mb time I got so far is like 21.935s. This was at like 3.9 Ghz, and Ram at 976Mhz Cas 4.
Sorry for no screenies, I am working on beating the fastest AMD SPi 1mb, which is like 21.21s w/ an FX57. Got about .7 to shave :P
Also, the install of windows is old, and the system was not tweaked. So stay tuned :D
SAD
Edit -
Dang.. just realized.. Roro has 21.21s on Hwbot, but KP has like 20.8'ish on Ripping. It sucks that KP isn't on HWbot anymore. Now I need to shave a full second off.
Uh max mem 104 for AMD 1m bro ;)
DDR2 is like having a peg leg in 1m. You'll need to push 600+ 4-4-4 somehow if you plan on being #1.
Was going to get one but that cold bug is absolutely awful :(
Hey awesome.. I will give those a shot tonight :D And time saving will be fun :D
AFI - you are right.. the coldbug sucks.. to hard to do dice. But pretty fun with phase.
As for the DDR2 I know what you mean.. what sucks is that the largest ratio I have is DDR800.. no 1066 :( But won't it be fun to see a peg leg go that fast :D
Challenges are fun.. so lets see what can be done :D
SAD
Would you guys agree that some of the best silicon goes into the 5200+? After all, it has a lower TDP than the rest of the line up and has the full 1mb of cache per core.
Ya I think so too, I had a couple 5200+ CPUs that easily hit 3GHz on slightly under stock voltage, and with 1.45 volts they can hit 3.5GHz
What do you guys think about
www.lagoom.com??
Cause that is where I just ordered my X2 6400+ from.
CHEAP AND WITH FREE SHIPPING
CCB8F 0717MPMW Will post results in 4-8 business days :)
I did a run with my x2 5600+ Here is the validation.
http://img208.imageshack.us/img208/1...idationia9.png
http://valid.x86-secret.com/show_oc.php?id=235678
It was a great improvement for me under the same cooling (Air) from 3.402Ghz
Made a run Super PI 1M. got a 25s final on it. I will try to beat K|ngp|n's score as soon as I get a container or make a "ghetto" one for some DICE action. As for now:toast:
Nice result Jass. Is that stable or suicide shot?
What's the stepping of that one?
You'll have to shave off over 4 seconds to beat the WR.. Good luck beating the coldbug :)
